Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 04-26-2004   #1 (permalink)
any place to get smaller turn signals?
forks when pushed really hard especially down hill in canyons, get a little flexi..not dangerous but some movement seems to be happening. any clues?
front brakes seem to get teensy bit soft is pushed really hard.any clues?
and, injection blurbly on low end when hot.any clues?
oh yeah, had that oil light problem too, just went away after bike developed an oil leak..message from an unhappy not to be leaking triumph? ps-dealer caused leak..not oem.
Old 04-27-2004   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Lockhart Phillips make all kinds of smaller turn signals. You just have to decide what you like. Any dealer worth the name should have a selection of those.
You must be riding much harder than I do to get your forks to flex. If you adjust the preload and damping, you can change the characteristics of the bike's behavior up to a point. Take a look at the thread about race settings for that information. If that doesn't work, then you belong in the AMA and probably need to have your forks professionally set up.
Over time, a little water or air can get absorbed into your brake fluid. The real fix is to change the fluid and bleed the brakes. In the mean time, you can pull your lever back to the grip, tie it there, and leave it that way overnight. That will harden up your brakes really well. If you are making your brakes fade, then you are using them very, very hard and you might want to experiment with other pads. I don't have any comments about what works, since I find the stock pads adequate for my purposes even on track days. Then again, I am a slow old man!
The engine trouble light will go off after three cycles. The oil light goes off if you have the right oil level and sufficient oil pressure. The engine trouble light is more of a caution light. The oil light means shut down the engine NOW! Where is the oil leak? It might not be that difficult to stop.
Hope this helps.
Will
SponsorHouse profile
Bulbs for NB Bullet indicators/ turn signals FrankBlack RAT - United Kingdom 1 02-21-2008 12:37 PM
LED turn/hi-beam/neutral indicators TroyH Club Cafe 9 07-30-2007 11:17 PM
Sef cancelling turn indicators from the legend RJScotti Hinckley Classic Triples 3 10-23-2006 11:04 PM
Rizoma "zero" turn indicators cooks7 Speed Triple Forum 2 05-05-2006 12:30 PM
