Hi guys, this is quite a long one so bare with me...
Long ride (4 hours) in torrential rain - after which bike starts playing up. Stalling and misfiring all over the place. Take it to the garage who tell me one of the spark plugs had water in it. After a new spark plug and coil (which was damaged from the water) I get the bike back.
Now the bike is showing the following symptoms:
• It feels very retarded. After a ride out today it was only kicking in about 8,000 rpm and even then didn't feel anything like it used to.
• At idle it seems to 'chugging' slightly but the tick over is fine. It isn't stalling or anything but you need to up the revs to about 6,000 to get the thing moving from stationary.
• There is virtually no acceleration/power anymore, and it almost feels like it's not firing on all four cylinders.
• There is a high-pitched whine when decelerating which wasn't there before. Almost like a turbine spinning down. This is a new noise and not one that was there before.
• The problem is intermittent. Some of the time it's kicking in just fine, other times it wont. It seems to consistently happen at lower revs though.
I'm pretty sure it's to do with the plugs/coil/etc but hoping you guys might have some more specific ideas. Could it be to do with the new coil/plug? Might it be the mapping which is out? Could it be the distributor? Please help! Any suggestions would be gratefully received.
[ This message was edited by: oxon_tt on 2006-01-29 16:57 ]
