Cutting Plastics - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!Ontario TourismNew Bonneville
Old 01-23-2006, 12:54 PM   #1 (permalink)
Does anyone have any tips for cutting fairing plastic/ windshield plastic??? i.e. what types of blades to use, and machinery.
Thanks for your help.
Dominic
I'm a man without prejudice, I hate all people equally.
Aviator2007 is offline   Reply With Quote
Old 01-24-2006, 06:12 PM   #2 (permalink)
You might go to a home center, and see what they sell or recommend to cut lexan. If you are just trimming it, a sharp utility knife might work.
Joe-Dirt is offline   Reply With Quote
Old 01-27-2006, 04:01 PM   #3 (permalink)
If it's finsihed rememeber to tape off the cut area to avoid peeling.
Kakolman is offline   Reply With Quote
Old 01-27-2006, 05:44 PM   #4 (permalink)
you could run over the edge with a soldering iron to seal it again
just a thought!!!!!!!!
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 01-28-2006, 09:17 AM   #5 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
It is a lot like cutting wood, except that you want to use the finest tooth saw you can get your hands on, and you want to use a low speed setting, like cutting metal, so you don't melt the plastic. For crash bungs, I just used a regular hole saw and used a fine wood rasp to reshape the edge where I missed a little. I then used a metal file to finish it smooth. For other cuts, I have used a metal cutting blade on a saber saw, also running a low blade stroke speed. The same finish and fine shaping tools work on that, too. For cement on painted OEM plastic, I use ABS cement from the hardware store. For things like the air intake nozzles, I use adhesive silicone sealant if the tabs broke off. I haven't done any experiments with the clear plastic, so I don't know what works on that without messing it up.
Will
SponsorHouse profile
Old 01-29-2006, 07:20 PM   #6 (permalink)
Thanks allot for the comments, I'll tell ya'll how it goes.
Dominic
Trophy plastics Stevumph RAT - United Kingdom 7 12-20-2007 10:21 PM
Daytona racing plastics ender Triumph SuperSports 11 09-28-2007 11:14 PM
Plastics needed beatpusher Speed Triple Forum 1 05-25-2007 12:07 PM
Plastics Painting ResearchRat Daytona Deliberations 15 03-23-2007 08:27 PM
replacement plastics tineg Triumph SuperSports 4 07-25-2005 06:38 PM
