My limited understanding of engine tuning leads me to think that's not the case at all. If the fuelling on the map you run is too lean for the engine you can cause quite extensive damage through internals getting too hot. Taking it to a specialist would be the correct option with the customisations Lowey's done, or so I would have thought.
True enough; definitely a dyno developed map is best (plus, you can tune it for whay YOU like). Finding and contacting the author would go a long way toward giving me some confidence -- could be bubba playin' with his laptop or a dealer/race shop who has custom mapped a track bike using a dyno and ega. My bet is a map on the PC web side is probably closer to the latter.
I assume Lowey found the map on PC's web site (there's one listed for a Two Bros slip on, which is probably pretty close to a Blue Flame pipe for flow and backpressure).
I'm not sure where the maps on PC's site come from, but it's hard to believe they would just post 'any old map'. User submitted maps seem to be listed separately. If it were me, I'd download the map, look at what kind of fueling bias is in it (you can do that with a PC, right?), and give it a shot if it didn't look weird (like leaner than stock).
