rear preload - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 01-20-2006, 06:47 PM   #1 (permalink)
hi all , how do you go about changing the rear preload it says in the manual that the dealer has to do it!! surely not
i have read the suspension sticky but its not in there
cheers
russ
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 01-20-2006, 10:35 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
There are wrenches for doing that. I don't have one, unfortunately. You unload the rear of the bike by hanging it from the garage rafters (if you are me) or some other way (if you are more sane or more creative) and loosen the bottom ring. Then you crank the preload up as much as you want then retighten the bottom ring good and tight so it doesn't back off again. I have used a long screwdriver and a hammer to tap the rings to tighten and loosen them without jacking up the bike, but that is not exactly the recommended method, and I haven't tried it on a Triumph.
Will
SponsorHouse profile
Old 01-21-2006, 05:22 PM   #3 (permalink)
will , i have changed the rear suspension settings to the road settings but the preload is still as it came out of the factory 37 threads instead of 44, will this be a problem??
[ This message was edited by: hinkleyboy on 2006-01-21 15:23 ]
Old 01-21-2006, 08:35 PM   #4 (permalink)
How much you weight? Preload is basically matching the bike's sag to your weight. You need a tape measure and a helper to properly set preload.
TTsixxer is offline   Reply With Quote
Old 01-21-2006, 08:54 PM   #5 (permalink)
13 stone ish
Old 01-22-2006, 04:41 AM   #6 (permalink)
Hinkleyboy
I weigh around 13 stone - between 13st7lb & 12st7lb depending on how many pies.....lol
TT sixxer is right about the best way to set preload except I haven't got any friends :-D .
So instead I use the PB settings in the sticky suspension sticky from Triumph Supersports forum
In fact I set front & back to PBtrack for a trackday last year and have gone back to PB road at the front but not the rear. That felt good all summer.
Now it has got colder it feels overdamped which I think is a mixture of thicker oil and me not going for it so hard on slick roads so to get the very best I should probably go back to standard damping. Except it is cold in the garage & I am not riding as much .... Alright I feel guilty now I will probably reset it tomorrow.
As preload affects the bike's attitude & ride height not the spring rate that would stay the same.
Happy for any of the more active suspension tuners to correct this.
Also a query from me for any suspension wizards I have just changed tyres from 010s to Diablos and the ride feels harder or noisier - a bit less compliant. Are the tyres that different or is it just a new thick tyre carcass not flexing much in cold weather :???:
Jon
Old 01-22-2006, 05:28 PM   #7 (permalink)
On 2006-01-22 02:41, lcjohnny wrote:
Hinkleyboy
Jon
My settings are similar to that exept my compression and rebound settings. On the front my compression is .25 from full in and rebound is .75 from full in. On the rear my preload must be more than 44 threads showing because it's cranked down quite a bit because I weight close to 200. My compression is .25 from full in and rebound is .50 from full in.
Making the forks rebound less stiff than its compression is very important to keep those headshakes in check.
[ This message was edited by: TTsixxer on 2006-01-22 15:29 ]
Old 01-22-2006, 06:19 PM   #8 (permalink)
do you have to hang the bike up or can you do it with the suspension under load??
Old 01-22-2006, 06:46 PM   #9 (permalink)
I helped my mechanic change preload using the screwdriver/hammer approach mentioned by Will. Although we had the shock spanner wrench, there wasn't enough room around the shock to use it. The bike was simply resting on its tires and the sidestand. It took maybe ten minutes to do.
[ This message was edited by: DaveC on 2006-01-22 22:37 ]
Dave
DaveC is offline   Reply With Quote
Old 01-22-2006, 08:26 PM   #10 (permalink)
Get a couple of these:
http://www.motostrano-store.com/ohshspwr.html
WELL worth the money!
Zane
2003 Triumph Speed Four
2006 Honda RC51
2009 Triumph Street Triple R
zaner30 is offline   Reply With Quote
Rear Preload on 05-07 Model S3 Monkey Trumpet Speed Triple Forum 5 08-21-2007 08:39 AM
955i Rear Preload Colin955Devon Daytona Deliberations 2 08-02-2007 04:04 PM
'05 S3 rear preload Martin_R Speed Triple Forum 1 05-22-2005 03:30 AM
Setting rear preload unummyu Sprint Forum 15 08-31-2004 04:03 PM
Rear Preload SP3inAZ Speed Triple Forum 9 06-23-2004 08:57 AM
