having a nightmare getting the gasket on the stator as its metal i cannot get it to go straight ( flat ) on to the the stator cover without
rises in it here and there, i tried holding it in place with the silicone
but no luck, so have cleaned it all back, and now waiting for any good advice
I can tell you from experience that it will leak if you use silicon sealant on it. It is pretty frustrating until you figure it out, or better yet, take advice from DEcosse. That's actually a pretty good idea when it comes to anything about the charging system.
Will
It's a squid thing. You wouldn't understand. SponsorHouse profile
I ran into the same thing when I replaced the stator and r/r... I remedied it by holding the bottom of the cover w the left hand, top w the right. And alot of swearing.
It took some shimmying, but then just went into place.
