stator gasket probs - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 01-16-2013, 01:56 PM   #11 (permalink)
Main Motorcycle: 2001 TT600
I've had my stator cover on & off about 3 or 4 times now. I agree with DeCosse, a screwdriver might be a little to risky; I used some the second time, & lo and behold some lovely dents showed up on the gasket... Ordered a new gasket (it came wobbly, not flat), and wrestled to get it back on. Instead of screwdrivers, I now just use my fingers (which of course get smashed like 80 times in the process!) ...I don't think there's an easy way to perform the task; that magnet & orientation & keeping gasket in place... I somewhat agree with Will, the first time I used silicone & it leaked oil. Thinking I went too light on the silicone, I opened 'er back up and put a little more on there. Hasn't leaked since, so take that for what it's worth.
supaevan is offline   Reply With Quote
Old 01-17-2013, 03:08 PM   #12 (permalink)
Main Motorcycle: TT600
bikerboy1's Avatar
Extra Motorcycle: pushbike
Originally Posted by ramenboy... View Post
I ran into the same thing when I replaced the stator and r/r... I remedied it by holding the bottom of the cover w the left hand, top w the right. And alot of swearing.
It took some shimmying, but then just went into place.
Good luck!
All DONE, APART FROM A BIT OF OIL, & COOLANT, TOOK ME ABOUT 30 MINs. found a dowel on stator casing held gasket on this with one hand
and with the other put cover sraight on. no leaks and no sealant used, let you know how it goes. THANKS for all the advise as i
could not have done this without your help
CHEERS
bikerboy1 is offline   Reply With Quote
URGENT help need on stator/engine case. can't get stator off gregpinch Twins Technical Talk 3 09-22-2012 02:26 PM
metal stator gasket mark1200 Daytona Deliberations 3 07-20-2011 04:06 PM
Stator recall/defect? 3rd stator just broke. bostonbuck Speed Triple Forum 7 04-10-2011 10:44 AM
Stator test correct? Will S4 stator work? redl1nerpm Triumph SuperSports 7 10-09-2008 11:44 PM
Underseat tray? Type of gasket sealant for sump gasket? ladyhawk Daytona Deliberations 0 09-11-2008 05:30 AM
