D650 shifting problem - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-16-2006, 11:16 PM   #1 (permalink)
mikmoo
Whenever my D650 gets warm (i.e 190 degrees) and I shift into neutral it sitcks there and won't shift out unless I roll forward or back. Is this a common problem with the Daytonas??? The dealer told me his bike (also a D650) does the same thing and not to worry about it......but I'm not quite sure I want to leave this problem alone. Any help is much appreciated!!! Thanks.
Mike
Old 01-17-2006, 06:25 AM   #2 (permalink)
My TT600 used to do a similar thing, but my D650 has been perfect. It was never really a problem. The method I used was to let the clutch out a little whilst pushing down into first, and it would clunk in.
plagued is offline   Reply With Quote
Old 01-17-2006, 07:51 PM   #3 (permalink)
Does this happen when you shift into neutral while already stopped? If it is, then try shifting into neutral while you are still rolling a bit, just before you stop.
Joe-Dirt is offline   Reply With Quote
Old 01-19-2006, 04:04 PM   #4 (permalink)
Other Motorcycle: Duc999/S3/D650
My D650 does not have this problem (yet, at least).
Billybob
Billybob is offline   Reply With Quote
Old 01-19-2006, 07:39 PM   #5 (permalink)
mikmoo
Thanks for your responses!!! I'll give them a try and see what works. :-)
False Neutrals & Shifting Gear Problem scobell Speed Triple Forum 15 10-14-2007 05:07 PM
d650 after paint Aviator2007 Triumph SuperSports 6 12-04-2006 08:03 PM
d650 acceleration neilmac Maintenance & Workshop Talk 0 07-24-2006 06:38 AM
D650 vs S4 DaveC Triumph SuperSports 2 11-18-2005 06:51 PM
Shifting problem Spooner Hinckley Classic Triples 11 10-08-2004 06:13 PM
