I have a new to me 2000 tt600. I am changing the chain & sprockets on it. the rear aluminum sprocket was badly worn on the inside so after some hunting on here I found some possible culprits, one of which is the front sprocket being installed wrong.
I took the old front sprocket off and noted which side was out(thick or thin shoulder) and compared it to the new one I had.
The new sprocket I have has writing stamped on one side, I figured that side would go out, but if I put the new one on with the writing out It would be exactly the same way as the one I took off.
So I just want to double check, does anyone know if the thick or thinner shoulder goes out?
