Why are my headlights draining my battery - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-26-2012, 11:50 AM   #1 (permalink)
Main Motorcycle: Daytona 600
Could this be a relay or something. When they are unplugged the battery fina at tickover but when I plug them back in it drains the battery quite fast at tickover. If its revving its fine.
I know people have said dodgy R/R but I have tried a couple of them now and its the same.
alan36 is offline   Reply With Quote
Old 11-26-2012, 12:29 PM   #2 (permalink)
Legend
DEcosse's Avatar
You have a generating system failure - if not the R/R, probably the stator.
Simplest test for stator - unplug it and leave ignition/engine off.
Measure resistance from any of the three pins to any engine ground point:
if short, your stator is toast.
Old 11-26-2012, 04:01 PM   #3 (permalink)
Surfguygriff's Avatar
What is your charging voltage at idle?
Surfguygriff is offline   Reply With Quote
Old 12-02-2012, 07:11 PM   #4 (permalink)
Main Motorcycle: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
Condition of your battery?
Not the volts, but the CCA. New they are in the 180 ball park. It can show 12+ volts but with no amps behind it, it won't do anything and the lights will drain the battery very quickly.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 12-02-2012, 07:15 PM   #5 (permalink)
Legend
DEcosse's Avatar
^^^ irrelevant once bike is started
Definitely a generating system problem.
Alarm Draining Battery!!!!!! excalibur1984 Maintenance & Workshop Talk 2 05-10-2011 03:06 PM
draining battery dojjja Daytona Deliberations 2 03-23-2010 03:21 PM
Something draining the battery Pipes73 Maintenance & Workshop Talk 4 09-08-2009 07:25 PM
battery draining hodgy T3 Sport / Touring Forum 4 07-19-2008 12:31 PM
Draining battery continues.. whodkne Speed Triple Forum 7 05-07-2007 11:33 AM
