Too much oil? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-19-2012, 09:58 PM   #1 (permalink)
Main Motorcycle: Speed Four
Too much oil?
So I bough my 06 speed four a couple weeks ago with 4500 miles on it. After about 500 miles, the oil light came on. I checked the oil and the level is way above the ideal line on the dipstick. I mean WAY above it. Would that cause the oil light? And if so, why didn't it happen sooner? I didn't add oil so it was high from when I bought it.
What do I do?
Sent from my HTC One X using Motorcycle.com Free App
Bugler is offline   Reply With Quote
Old 11-20-2012, 05:04 AM   #2 (permalink)
Main Motorcycle: Speed Four Neon Blue 2005
My level always seems a lot higher than the mark too. If ur unsure of the oils history I would probably change it. I know I put the right amount in and it measured fine for a while. I don't worry tho as I know the oil is good the amount is good and there. Isn't any water etc getting in there. I don't think too much oil would put the light on but can't say for sure
Sent from my HTC Desire C using Motorcycle.com Free App
SpeedFourDave is offline   Reply With Quote
Old 11-20-2012, 08:35 AM   #3 (permalink)
Main Motorcycle: Tiger 800
2008superduke's Avatar
Other Motorcycle: Daytona 600
Check on the left right side of the engine and there is a small sensor with a wire coming off, that is the oil sending unit(sensor/you have engine oil problem) check to see if the wire is still attached. I would do an oil change! gives you an idea as to how much was in there and you can add the right amount. Kind of see the quality of oil(really dark or bits in it)
2008superduke is offline   Reply With Quote
Old 11-20-2012, 10:40 AM   #4 (permalink)
My girlfriend has a four as well and her level looks right on the mark. I'll drain some today and make sure it's the right amount.
Old 11-20-2012, 04:34 PM   #5 (permalink)
I took almost a quart out. Wow. Anyways the light was still coming in so I removed and cleaned the oil pressure switch and reinstalled it. That did the trick. Not sure what caused it but it's fixed now.
Old 11-20-2012, 07:27 PM   #6 (permalink)
Main Motorcycle: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
Corrosion builds up between the screw and the sensor, causing the problem. Cleaning it takes care of most of the time.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
