AdvanstarMotorcycleShowsMotorcycle.comBikeBanditTrident-Exhausts.com
Old 01-12-2006   #1 (permalink)
left hand side stator cover/generator cover has had oil coming off it for a while so took the fairing off and there was oil leaking from where the wires go into the cover
so i covered it in silicone sealent to try and plug the leak as that is what a triumph guy said they do with this problem so next big ride i will see if it works
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 01-12-2006   #2 (permalink)
That's the exact same point my 650 started leaking from. The rubber grommet had become unseated so they reseated it and it was fine, they ordered a new one and fitted it anyway to be sure. I believe you have to take the cover off to re seat it though so that would mean draining all the oil.
plagued is offline   Reply With Quote
Old 01-12-2006   #3 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
That is not a completely uncommon problem. The grommet is the sure fire way to solve it. I have heard of a few failed attempts to solve the problem with gobs of sealant.
Will
SponsorHouse profile
Old 01-12-2006   #4 (permalink)
i have been told that the grommet is part of the wiring loom and that u have to replace that as well
Old 06-14-2006   #5 (permalink)
Is it true that the wiring loom has to be replaced along with the grommet? I had a slight leak that I thought was coming from the gasket around the generator cover as the oil drip pooled up at the bottom. I replaced the gasket & I guess the problem was coming from the rubber grommet. I think I mangled it more replacing the gasket because after getting of the highway this morning on the way to work there was oil all over the generator cover & shift lever that seemed to be coming out of the rubber seal. I am going to go home and look at the micro fische and I hope that answers my question, but if anyone can answer this now it would help me with peace of mind for the rest of the day
Thanks,
Zane
2003 Triumph Speed Four
2006 Honda RC51
zaner30 is offline   Reply With Quote
Old 06-14-2006   #6 (permalink)
not entirely sure however my sealent fix has stood up to the test of time 6 months and no leaks!!
Oil leak from oil cooler pipe? FlyBri Twins Technical Talk 3 06-21-2007 11:58 AM
Oil leak, right-side oil cover Rincewind Tiger Workshop 2 05-30-2007 10:36 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
Tiger coolant leak solved. graeme Tiger Workshop 4 04-02-2006 07:09 AM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
