Official Leathers Tester
Site Supporter SOTP Vintage Series Main Motorcycle: Very fast 675
Posts: 6,159 Other Motorcycle: SV650 Track Weapon Extra Motorcycle: Mad Max the Husqvarna
It depends a bit on what you are doing and what the conditions are like. For every day street riding, going with the manufacturer's recommendations is a good idea. For high performance, carrying loads, or extreme conditions of one kind or another (heat, cold), you may want to adjust pressures. To get a little hotter tire surface, lower pressure. To run a little cooler or carry heavier loads, raise pressures. You will want to check with somebody who knows a whole lot more than me to make sure you have the exact limits of these things, but that's the general idea.
Will
SponsorHouse profile
