Extra Plug connector Help - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-19-2012, 01:53 AM   #1 (permalink)
Newbie
Main Motorcycle: 2002 triumph tt600
Hi folks,
I picked this Nice 2002 TT600 Last month I love the bike.
I decide to get my hands dirty and tried to change the spark plugs, I notice someone allready had worked on the bike , I found this cable from main wiring harnness floating on top of the engine , does anybody has any Idea were does it goes?
I plugged on to the Air box sensor and it makes a perfect fit , but I allready have a wire assigned to the box
I also notice one of the spark plugs was wet, meaning Oil on the tread ,not on the tip of the plug but arround the screw tread.
any advice will be greatly appreciated
thank you.
Extra Plug connector Help-imag0642.jpg   Extra Plug connector Help-imag0643.jpg
chapulin is offline   Reply With Quote
Old 11-19-2012, 01:55 PM   #2 (permalink)
Main Motorcycle: Triumph TT600 2000
Other Motorcycle: Peugeot xp6s50
I thought that myself! my one is disconnected too so i assume it is meant to be
Danmandrums is offline   Reply With Quote
Old 11-19-2012, 02:01 PM   #3 (permalink)
Main Motorcycle: 2000 TT600
SquarEuro's Avatar
According to some searching, the wire sitting loose with the grey connector is a california emissions thing that is not used on bikes from other markets. Honestly, I searched for this when I got my bike back in Sept, and failed to find a post by someone that had a bike that utilized that wire.
Searching also suggests that the oil around the plugs is from a leaking valve cover gasket.
I use google directly to search this site and other forums I'm on, it works pretty good. Just put your search phrase in google with "site:triumphrat.net". For example:
oil spark plug tt600 site:triumphrat.net
2000 TT600 | Black and Yellow | TOR pipe, K&N, 10166 map and some other stuff.
SquarEuro is offline   Reply With Quote
Old 11-19-2012, 07:49 PM   #4 (permalink)
Main Motorcycle: Tiger 800
2008superduke's Avatar
Other Motorcycle: Daytona 600
Your bike looks like it is in good shape. I have the same problem right now too a little oil on the plugs, threads.
2008superduke is offline   Reply With Quote
Old 11-20-2012, 01:42 AM   #5 (permalink)
Newbie
mistery!!!
Thank you for you all replys
heres what I found:
danielsg1 solutionsApr 28, 2009
I believe the connector goes to the California emisions junk. If you don't have a California motor, it should be orphaned. I have the same thing on my TT and that is what is according to the wiring data.
SHOWDAN19691 solutionsMay 05, 2009
THE CONNECTOR IS FOR THE MANUFACTURER TO PLUG INTO TO RE MAP IT, OR TO FIND FAULT CODES, I HAD THE SAME PROBLEM TRYING TO FIND WHERE IT CAME FROM. AFTER 2 DAYS OF WONDERING, I FOUND OUT FROM A DISC I BOUGHT OFF EBAY. I ALSO GOT IT CONFIRMED WITH A FRIEND WHO WORKS AT A TRIUMPH DEALERS.
I'll said the second option looks more reasonable, but still a mistery!!!
Old 11-20-2012, 02:54 AM   #6 (permalink)
Main Motorcycle: Speed Four Neon Blue 2005
It is the first solution. Has been mentioned many times on here before. The remap/diag port will be found under the seat for easier access and is a lot bigger and mine has a black rubber protecting it. Don't worry about it. I belive all the fours at least have it
Sent from my HTC Desire C using Motorcycle.com Free App
SpeedFourDave is offline   Reply With Quote
Old 11-20-2012, 08:38 AM   #7 (permalink)
Not the plug for diagnostics looks like a air emissions plug
Old 11-20-2012, 10:40 AM   #8 (permalink)
Main Motorcycle: 2001 TT600
Yes, that plug is for SAI (Secondary Air Injection), a California Emissions thing. If your bike isn't in CA, that plug doesn't do anything. It is not the ECU/Diagnostic cable. The Diagnostic cable is under the seat, on the brake side, like an 8 or 10 pin connector.
supaevan is offline   Reply With Quote
Old 11-20-2012, 12:18 PM   #9 (permalink)
Newbie
Bike has Texas Plates But Im in SoCal
What happens if I swich wires? Now I can't remember if the grey or black belongs to the thank ,
Does Texas has emissions rules same as California ?
small plug connector. moforuss Cruisers - America, Speedmaster 2 09-15-2012 10:12 PM
NARK and extra connector TX1911fan Twins Technical Talk 7 06-17-2012 02:58 AM
What is the extra plug under the seat on the 2011+ speed trip? spinkick Speed Triple Forum 5 11-23-2011 07:09 PM
Alarm Connector / Plug on '05 Tiger Tiger_50 Tiger Mods & Bolt-Ons (archive) 7 04-30-2008 05:16 PM
extra connector on LH switch assmbly Deacon Twins Technical Talk 9 12-18-2007 08:25 PM
