Help! New bike - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-17-2012, 06:57 PM   #1 (permalink)
Main Motorcycle: '04 Triumph Daytona 600
Help! New bike
hello, new poster!
ive only passed my test about 3 weeks, the following weekend, went out to 'look' at a bike, ended up buying it there and then, man shopping but maybe i was too hasty.
its a 2004 daytona 600, it rode fine for the first weekend, then a week later i went to fire it up and it was dead, i tried a few times but the more i did, the less reaction i got each time. i trickle charged it and thought that was the last of it, until i went to buy a new battery and ended up being recovered by a truck.
a friend who knows more about it than me has been having a look, he has concluded that the battery isnt being charged by the engine, its slowly draining, even with the headlights disconnected.
its annoying because i live and work 300miles away during the week so i can only fiddle with it at weekends, ive pretty much missed the last 2 weekends suitable weather this year for riding but thats besides the point, since replacing the battery it hasnt yet failed to start, but this is only a matter of time as the battery is still draining whilst its running. any help?
dan
spikekellyRM is offline   Reply With Quote
Old 11-19-2012, 02:58 PM   #2 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
Look for threads about the regulator rectifier. That's probably your problem. You may also have stator problems. There's been lots of discussion about those two components lately.
Will
SponsorHouse profile
Old 11-26-2012, 04:06 PM   #3 (permalink)
Main Motorcycle: Daytona 600
Surfguygriff's Avatar
Do a static draw test to see if you have a drain somewhere. Remove the negative battery clamp and connect your volt meter inline between the clamp and the post. You should read no higher than .01 amps as long as the bike is electronically stock (no alarm).
If it reads higher, start pulling your fuses until it drops to normal to isolate your problem.
Surfguygriff is offline   Reply With Quote
Old 11-26-2012, 04:07 PM   #4 (permalink)
Also, check your charge voltage at idle and at 3K RPM. Should be above 13.8 volts
Old 11-27-2012, 04:15 AM   #5 (permalink)
Taken it to a garage because id only make a mess of things.
Basically the left hand circular engine cover looked suspicious and there was silicone everywhere. Upon further inspection the cover had been removed then replaced with no gasket. Beneath that the generator has burnt out and taken the reg/rec with it.
It seems as if the previous owner has located the problem hence the removed cover, then decided to get rid,
I bought it from chapel in le frith car sales but it's not a proper dealer as such and was sold more as a private sale so I have no idea where I stand
Any advice would be appreciated
Old 11-27-2012, 12:42 PM   #6 (permalink)
Legend
DEcosse's Avatar
This pertains to cars but I'm sure it applies to motorcycles equally
http://www.adviceguide.org.uk/englan...ate_seller.htm
http://www.adviceguide.org.uk/englan..._is_faulty.htm
Contact them via the link at the top of the page and ask for advice on how to proceed.
If you otherwise like the bike, then get it repaired and try to get the costs covered by the seller - have you even contacted them and asked what they are prepared to do for you?
Also, familiarize yourself with this - http://www.oft.gov.uk/shared_oft/rep...08/oft1241.pdf
If dealer has premises that indicate he is a dealer/trader, and he sold the bike out of that premise, not his home, then he is a trader and subject to the requirements regardless of how he tried to portray the sale
I'm assuming this is your Daytona listed on this page - http://www.chapelenlefrithcarsales.c...usly-sold-cars
Don't see how they can profess that to be a private sale!!
Old 11-27-2012, 08:49 PM   #7 (permalink)
Main Motorcycle: Tiger 800
2008superduke's Avatar
Other Motorcycle: Daytona 600
I'm putting up a video in a few minutes on the stator removal and I did one on the rectifier replacement if that helps. The Stator is 120.00 the gasket is 22.00 a used R/R is 60.00 the new wire harness for new R/R is 13.00. little over 200.00 you got it fixed.
That sucks though that someone would do that. Sorry dude. If you want to fix it yourself PM me and I will walk you through it.
2008superduke is offline   Reply With Quote
Old 11-28-2012, 08:46 AM   #8 (permalink)
He offered to pay half instantly but I'm pushing for the full cost of repair. Just waiting on a fault report and invoice from the garage to forward to the dealer
Old 11-28-2012, 08:47 AM   #9 (permalink)
I was possibly a little hasty in flapping over where I stand. I'm off work this week and v bored, too much time on my hands. I think I'll be ok to be honest
Old 11-28-2012, 10:16 AM   #10 (permalink)
Main Motorcycle: Speed Four
Hope things have gone OK and you got the repairs covered. If not contact trading standards, as you are covered under the sale of goods act.
When it's fixed they are a cracking bike
Speed4Boy is offline   Reply With Quote
Had to sell my bike when I split with ex, joined for sympathy, for bike sale ofcourse streetbee The Welcome Center 0 10-04-2012 03:37 PM
Enter your Triumph Sports bike in this month's Bike of the Month contest Tbirdnz Triumph SuperSports 0 07-05-2011 04:54 PM
New Arrow 2-1, bike sounds like a Honda dirt bike!!! spumoni Twins Technical Talk 13 06-23-2011 04:47 PM
Yesterday's Bike and Bike Ride to Glenwood Canyon, Colorado Werks Sprint Forum 5 07-03-2010 10:02 AM
dont you love other dedicated bike forums talikng about your bike bakwheeltango Sprint Forum 11 07-31-2007 08:03 AM
