Cold Start problem on Speed4 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2012, 08:46 AM   #1 (permalink)
Just recently when starting the bike completely cold the fuel pump runs and when it stops I'll crank it for a few seconds and she won't fire. The fuel pump then runs again.
Now, if I try cranking it again no joy, however if I turn the ignition off and back on (once or twice) and then crank it will fire finally (but not quick).
No hot start issue at all. Fires right up.
What does this sound like? Fouled plugs? Fuel filter? Battery on the way out?
Thoughts?
TIA
We're in Italy and occasionally we get a dumbass Italian who decides to do something heroic and it all goes pear-shaped. -Colin Edwards
skiTTles is offline   Reply With Quote
Old 11-14-2012, 03:30 PM   #2 (permalink)
Main Motorcycle: 2001 Triumph TT600
Maxacon600's Avatar
Other Motorcycle: 1974 Suzuki ts185 Sierra
Extra Motorcycle: 1971 Honda "Trail" CT70
Sounds like an everyday occurrence to me! If it is below 45F here it takes forever. Just keep letting the fuel pump prime. I had some cracked vacuum hoses and thought those to be the culprit, I changed them out, changed the spark plugs too, same old eheeheheheheheheh in the morning! Put it in a heated garage, then try starting it. If it starts fine I am correct, if it does the same, there is a problem.
"All of these... moments... will be lost, in time... like... tears... in the rain..." - Blade Runner
Maxacon600 is offline   Reply With Quote
Old 11-19-2012, 02:55 PM   #3 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
If you rode the bike for a while and got it good and hot before shutting it off, try opening and shutting the fuel cap before trying to start the bike. It shouldn't matter, but sometimes it does. I suspect a vacuum in the tank when this happens. It shouldn't, but sometimes it does, and that's the fix.
Will
SponsorHouse profile
Old 11-22-2012, 04:19 PM   #4 (permalink)
Main Motorcycle: o2 triumph speed four
Got this from a previous thread... Ant find it now, but My speed four does the same at the beginning of the day. I turn the key, let the pump run, hit the ignition switch, won't turn over.
Try turning the key off and wait about 10 sec. Then hit the starter. I've done this the past year or so and it starts without fail.l
ramenboy... is offline   Reply With Quote
cold start problem, running on one cylinder. BirdoPrey Club Cafe' 5 08-18-2011 02:24 PM
Cold start battery problem geoff1960 Tiger Chat 5 01-01-2011 08:22 AM
Interesting cold start problem Snakeoil Classic, Vintage & Veteran 15 10-07-2010 02:21 PM
cold start problem chris5150 Triumph SuperSports 6 07-21-2009 07:01 PM
S4 Cold start problem zaner30 Triumph SuperSports 5 10-01-2006 02:41 AM
