Help please with this charging problem - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-12-2012, 03:08 PM   #11 (permalink)
Main Motorcycle: Speed Four
i replaced my stator and rectifier on 11-11-2012 and getting 13.5 at idle and 14.5 over 3000rpm
i was told if it is over your rectifier is faulty as it should not pass more than 14.5v as it will destroy your battery
have you checked your connections for corrosion and continuity
i bought my bike 2 months ago as a project and knew this was an issue luckily for me
the refurb stator and rectifer came with new connectors as the stator one was melted
i just cleaned the remaining ones and checked continuity.
hopways is online now   Reply With Quote
Old 11-12-2012, 07:38 PM   #12 (permalink)
Main Motorcycle: Daytona 600
Surfguygriff's Avatar
Doesn't matter if its new, its clearly not working properly or it was not properly wired to the bike.
Surfguygriff is offline   Reply With Quote
Old 11-12-2012, 08:47 PM   #13 (permalink)
Main Motorcycle: Tiger 800
2008superduke's Avatar
Other Motorcycle: Daytona 600
Where can you get those connects BTW That beaver electrons place?
2008superduke is offline   Reply With Quote
Old 11-12-2012, 09:16 PM   #14 (permalink)
Yup, Eastern Beaver has never let me down.
Old 04-15-2013, 10:11 PM   #15 (permalink)
Main Motorcycle: TT600, speed four looks
Had a charging issue and after reading the sticky by Decosse I was able to determine my r/r had failed. Luckily I had a spare lying about and put it on. Now at idle I have 13.5 v instead of 12.45 from before
666stars is offline   Reply With Quote
Charging problem Mercracing Daytona Deliberations 1 05-31-2012 10:13 PM
Need help with electrical charging problem kryptonight07 Sprint Forum 13 03-22-2012 03:44 PM
Charging system problem geolpilot Twins Technical Talk 15 09-29-2011 12:19 AM
Charging problem I think.. stinky93071 Sprint Forum 6 06-04-2011 08:00 AM
Do I have a charging problem? trumpycam Twins Technical Talk 9 12-15-2009 05:45 PM
