Bike doesn't want to crank when it's warmed up - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 10-21-2012, 05:16 PM   #1 (permalink)
Main Motorcycle: 06 Speed Four
I have a 06 S4.
When it's cold in the morning, it fires up at the first try.
If I ride around to get it up to operating temps, if I turn it off, and try to crank it back up, it won't fire.
It does sort of fire up then immediately dies. I have to let it cool off before it will start.
I know it's not the battery. Any ideas?
Frosty_spl is offline   Reply With Quote
Old 10-21-2012, 09:02 PM   #2 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
It could be a clogged vent in the fuel tank. Usually that causes the reverse problem - starting issues when it is cold. It is worth a look anyway.
Will
SponsorHouse profile
Old 10-21-2012, 09:21 PM   #3 (permalink)
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: '01SV650S sold
Checked valve clearances lately? Tight valves may do this.
Felony is offline   Reply With Quote
Old 10-24-2012, 09:28 AM   #4 (permalink)
I will check the fuel tank vent. Where is it anyway? haha
The bike did it since I bought it last year. After I got it, I had the dealer do a full service.
It seems to have gotten worse. Months ago, it wouldn't do it often at all, and if so, it would take 3 tries to get it to crank. Now it's dead in the water until it cools off.
Old 10-24-2012, 04:47 PM   #5 (permalink)
Main Motorcycle: 2000 TT600
SquarEuro's Avatar
I'm a total noob when it comes to these bikes, but in old volvos usually a hard warm start is due to a bad coolant temp sensor, crank position sensor/hall effect sensor or one of the FI relays. I don't know if that gives you any ideas.
2000 TT600 | Black and Yellow | TOR pipe, K&N, 10166 map and some other stuff.
SquarEuro is offline   Reply With Quote
Old 10-24-2012, 08:35 PM   #6 (permalink)
Will's Avatar
Ah, yes, that's worth trying. The 2000 TT600 I had indicated overheating because the sensor went TU, and it wouldn't start because it thought the motor was warm when it wasn't. Good suggestion.
Will
Old 10-24-2012, 09:10 PM   #7 (permalink)
Would it throw a code if a sensor is bad?
Old 10-25-2012, 02:22 PM   #8 (permalink)
Will's Avatar
I don't think so. I don't recall any engine light coming on when my temperature sensor went off.
Will
Old 11-08-2012, 08:20 PM   #9 (permalink)
My air idle control valve was disconnected. The dealer charged me $247 to diagnose it and plug it back in.
Bike doesn't like to crank when its warmed up. Frosty_spl Triumph SuperSports 5 12-28-2011 10:51 PM
Bike won't crank!! skyhigh21 Daytona675 Forum 1 12-04-2009 12:14 PM
bike wont crank! LuckyDogSE Daytona675 Forum 4 11-09-2009 04:10 PM
Bike for sale with 76 Offset Crank? Normsthename Classic, Vintage & Veteran 1 09-14-2008 02:34 PM
Another 360 degree crank bike arriving soon ohiorider Twins Talk 1 08-27-2008 09:07 PM
