BikeBandit
Old 12-22-2005   #1 (permalink)
What hardware would I need to fit TT600 race bodywork to an S4? Obviously the tail is no different, but what about the rest?
Also, has anyone fit a D600/650 race tail to a TT600? I prefer how the D's tail looks.
I think the Speed Four would make a fine track toy...
NorCalS4 is offline   Reply With Quote
Old 12-30-2005   #2 (permalink)
skybolt
I can't answer your question, but I would be curious to find out if you have been able to find reasonably priced TT plastic. I don't plan on messing mine up, but you never know! :-D
skybolt
Old 12-31-2005   #3 (permalink)
surely it should just be a case of getting the brackets as well as the plastics as the bikes are identical
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 12-31-2005   #4 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
TT600 plastic can be pretty tough to come by, but Sharkskins makes good race plastic for a whole lot cheaper than OEM. You will need all the brackets for starters. There are two L shaped brackets that bolt to the outside of the frame spars. You have to drill and tap at least one of the holes, if not both. There are brackets that bolt to the radiator. I don't know if the S4 radiator is set up for that or not. There is a bracket that holds the headlight and upper faring. Then there is the headlight itself. The headlight wiring is different. The ram air tubes are different, and there is a radiator shroud. There might be something else I am missing. It is certainly worth doing if you have an S4 and would rather have a TT600 with some wind and weather protection, but it isn't quite as straight forward a bolt up job as you might think on the surface.
Will
SponsorHouse profile
Old 12-31-2005   #5 (permalink)
I'll say
thanks,
-Andrew
burgessa23 is offline   Reply With Quote
Daytona Race Plastics Photo? nyburner Triumph SuperSports 9 12-23-2007 09:09 AM
self fitting frame sliders to speed four Hedge600 Triumph SuperSports 3 08-02-2006 11:20 AM
02 Speed Triple not accepting full coolant load? Catamount Modifications & Workshop Talk 3 05-20-2006 08:22 PM
Full Fairing Speed Triple? Evoking Speed Triple Forum 6 03-03-2006 04:34 PM
full race thruxton - I thnk buggy Club Cafe 16 03-20-2005 10:44 AM
