Wiring harness questions - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-11-2012, 12:08 AM   #1 (permalink)
Main Motorcycle: speed triple
I have a question for you triumph people out there. I currently have a 2001 tt600 which has had the fuel injection section of the wiring harness which has been hacked up by the previous owner (it has multiple spices in it from a wideband commander for data logging). My question is if there are idifferences in the harness between the different years of these bikes. Any help would be greatly appreciated!!!!!
nfakbc is offline   Reply With Quote
Old 07-11-2012, 12:59 PM   #2 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
they should all be the same. My guess is the hacked harness is causing your problems.
Will
SponsorHouse profile
Where to get Wiring Harness? Beemie Classic, Vintage & Veteran 14 11-01-2010 09:05 AM
What wiring harness should I go for? Hamos Classic, Vintage & Veteran 14 09-16-2010 06:50 AM
Building homemade wiring harness, a few questions. internet ay Classic, Vintage & Veteran 13 05-18-2010 05:59 AM
I Need Wiring Harness Help JEB Twins Talk 12 03-05-2007 10:01 AM
wiring harness quagmire Classic, Vintage & Veteran 2 10-08-2005 09:56 PM
