Front brake not illuminating brake lights - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 02-17-2012, 01:16 AM   #1 (permalink)
Main Motorcycle: Triumph Daytona 650
So the foot brake nor the hand brake were activiating the brake lights. I found out the problem for the foot which was the plunger/switch. THe hand brake on the other hand is a different story. I can't sem to find the problem. the brake works fine its just the light. Is their a plunger/ switch somewhere I can't see? A friend told me their might be a button or switch located somewhere but hes not sure since he owns a buell. Can anyone help? or have a way to download a wiring diagram? thanks
Mr.EVO is offline   Reply With Quote
Old 02-17-2012, 01:52 AM   #2 (permalink)
Main Motorcycle: 2000 TT600
There are 2 wires that connect near the brake lever, those are for the switch there. Find 'em. See if perhaps one or both are disconnected. If not, follow them and find where the break in the circuit is.
'00 TT600
'87 GN
GNTurbo6 is offline   Reply With Quote
Old 02-18-2012, 02:07 AM   #3 (permalink)
okay i will look for the wires your talking about, do you also happen to know why my left blinkers blink alot faster then my right, about twice as fast. Is it a fuse or something else?
Old 02-18-2012, 08:04 AM   #4 (permalink)
Main Motorcycle: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
Usually means a blown bulb on that side (aka left side).
Did you install an LED bulb? Those also cause fast blinker rates because they don't have the same resisance an regular lights.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 02-18-2012, 08:07 AM   #5 (permalink)
Main Motorcycle: Very noisy Daytona 600
Means a break or short in the circuit. Usually happens when a bulb has blown. Are they all flashing? Check fuses.
I would check that the two live wires to your brake lever are connected as GN says. They are hard to spot, two tiny black wires on spade connections to the underside of the throttle housing. Failing that, check the two (blue?)live connections to the horn above your front mudguard. They take a lot of abuse being so exposed to the weather, and your front brake light circuit takes its live from there. Have you had the front fairings off? If so check the barrel connections between the bike and the indicator mounts have been pushed home properly. If you have a multimeter, you could check that the switch at the lever is functioning correctly.
Scorch is offline   Reply With Quote
Old 02-18-2012, 04:57 PM   #6 (permalink)
I don't know exactly where the barrel connections are or what they look like. I borrowed a mutimeter but don't know exactly where to test the switch at.
Old 02-18-2012, 06:25 PM   #7 (permalink)
If you were to take the fairings off that your indicators mount on, you find that Triumph have included a small tubular shaped plug/socket to allow you easily disconnect the indicators from the bike and remove the fairing completely.
To check that your brake light switch is working, look under your throttle, you will see two shiny black plastic plastic coated terminals. These are the terminals from the brake lever switch.
Brake Pedal not illuminating stop light - 95 Tbird Denno69 Maintenance & Workshop Talk 5 02-24-2009 07:57 PM
Brake light not working for front brake uber Speed Triple Forum 2 06-24-2008 05:50 AM
front brake / brake light question JACKAL Maintenance & Workshop Talk 2 04-11-2008 05:44 PM
Brake trouble, anybody else rebuilt the front brake Master cylinder uzidzit Twins Technical Talk 3 10-13-2007 12:55 AM
