Rear wheel spins in neutral - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old 02-16-2012, 07:57 PM   #1 (permalink)
Main Motorcycle: Daytona 650
Other Motorcycle: GSXR 1000, GSXR 600
So this might be a retarded question... and it might be totally normal. I hadnt started up a bike while on the rear stand in a while but I did tonight. My D650 in Neutral the wheel spins, not fast, and I was in neutral... thought I was crazy and shifted up and down... anyways like I said it might be normal but I cant seem to ever remember seeing that before. Then again any other time I started my bike on the rear stand it was to clean and lube my chain which I always did in first gear...
sorry in advance if this is the most retarded question in the world...
I suppose I could take the D650 off the stand and see if my GSXR does it too but it seems like too much work this late at night...
***edit*** oh yeah the only reason I think it might be normal is because it barely moves, a little pressure and it stops... not as if it were on its side stand it would roll off and fall down... the friction of just being on the ground would keep it from moving...
Google First... Ask Questions Later... - Me
k-nutz is offline   Reply With Quote
Old 02-16-2012, 08:02 PM   #2 (permalink)
Main Motorcycle: 2011 Triumph Tiger 800
My 2009 Sprint does the same thing when it is cold. Once the oil warms up a little, it stops.
Getiton is offline   Reply With Quote
Old 02-16-2012, 08:04 PM   #3 (permalink)
well that explains it then... thought I was losing my freakin mind haha!!! thanks for the super fast reply...
Old 02-17-2012, 08:37 PM   #4 (permalink)
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: SV650 Track Weapon
Every bike I ever owned did that.
Will
SponsorHouse profile
2006 America - Rear wheel is still driven in neutral kdknigga Twins Technical Talk 12 11-03-2010 08:48 PM
Help. Back wheel still engaged while in Neutral Willyrover Twins Talk 7 10-21-2008 07:34 PM
Back wheel spins while on Centre stand NorthVancpF Twins Technical Talk 12 05-01-2008 09:58 AM
Back wheel moves in neutral?!?! dkurtz Triumph SuperSports 4 01-06-2007 02:16 PM
Wheel spins in neutral?? pabonne Twins Technical Talk 6 09-21-2006 06:12 AM
