Motorcycle.comTrident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
Old 10-10-2005   #1 (permalink)
captkirk
I did a little looking around but found no answer. Has anyone come up with a better way to fasten the seat? Pulling up the corner of the seat and wedging in an Allen wrench is fast getting old.
Old 10-11-2005   #2 (permalink)
I use an angled allen bit in a screwdriver. It's basically a ball shaped bit designed to allow you get grip from any angle, so you can just keep the screwdriver at 45 degrees odd and twist. I'll try and find a picture of one. I got it in a specialist driver bit set.
What are you removing the seat for? I've only had to remove mine twice in 8 months?
plagued is offline   Reply With Quote
Imperial fasteners on 06? Jonny955 Tiger Workshop 7 08-28-2007 03:38 PM
Daytona seat Stevumph Trophy 1 02-24-2007 06:37 PM
Daytona Seat fldaytona6er Triumph SuperSports 0 11-28-2006 03:13 AM
fasteners azrider Classic, Vintage & Veteran 6 09-07-2006 12:36 AM
Bonneville T100 Seat fasteners Hogdad Twins Technical Talk 13 07-20-2006 05:26 PM
