Can anyone tell me if the clocks on the D600/D650 are "servicable"? Can I open them up to replace a backlight bulb or are they sealed units like on my old Ducati 749.
Yes, you can replace the back and indicator lights. You'll need to remove the nose fairing to get to the instrument mounting screws and the electrical connector on the backside of the panel. Once these are removed, remove the smaller screws that hold the two panel halves together. Keep the panel with the lens side down while you split the panel. You will now be able to unscrew the bulbs from the circuit board. Make sure to keep track of the bulbs' orientation, as they are different for back-lighting and indicators.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
