BikeBandit
Old 09-22-2005   #1 (permalink)
When I open my fuel tank, I turn the key all they way, and then I have to pull up on the cap sorta hard to get it to open. When it opens, a bunch of air rushes down into the fuel tank. Is it normal for the cap to have this much suction from the fuel tank?
kjartan is offline   Reply With Quote
Old 09-22-2005   #2 (permalink)
ive never had that problem with my tt or zxr but when i unscrew the filler cap on my car there is always a rush of air into the tank have you checked the breather pipe?
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 09-22-2005   #3 (permalink)
I had the identical problem with my s4. Dealer corrected it under warranty. Kinked vent line.
Live and let live
punisher is offline   Reply With Quote
Old 09-22-2005   #4 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
The other possibility is an incorrectly positioned tip-over valve in the vent line. I bet you have trouble starting it when the tank isn't full and the temperature has dropped (ie after it sat outside for a cool night).
Will
SponsorHouse profile
Old 09-22-2005   #5 (permalink)
ditto on the kinked vent line
dml955i is offline   Reply With Quote
Old 09-23-2005   #6 (permalink)
interesting, this has happened alot to me lately. I thought it was just something that happened. I'll look into it
Treehugger is offline   Reply With Quote
Old 09-23-2005   #7 (permalink)
jerrymoto03
DUDE! I have the same problem, It started after I took the bike in for ruptured fuel fitting. Is that normal or abnormal?
Old 09-23-2005   #8 (permalink)
Will's Avatar
Whoever put the fitting on probably got the vent hose twisted a little when the tank went back on.
Will
Suction in tank - Sometimes Burrben Speed Triple Forum 11 05-17-2008 02:41 PM
gas tank/suction txsport06 Triumph SuperSports 5 07-17-2006 03:21 PM
how many god***** litres of fuel in a ****** tiger fuel tank pastitoo Tiger Chat 16 05-08-2006 08:52 PM
Fuel Tank paint clogging fuel filters on Adventurer Hinckley Classic Triples 3 03-09-2005 03:41 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 09:23 AM
