Old 08-27-2005   #1 (permalink)
My S4 appears to need a 17mm Allen (hex) wrench in order to remove the front axle, so I can pull the front wheel...the shop manual says nothing about it as a special tool, & I don't have that wrench.
In many years of wrenching I've never needed a 17mm Allen before. Is this readily available at major auto parts stores, or is this something unique to Triumph?
B02S4 is online now   Reply With Quote
Old 08-27-2005   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
It can be a real PITA to find one. Look on ebay or a tool house. Sears doesn't have one, and none of the auto parts had one. It is the same size as the oil drain plug for a whole lot of German cars, including BMW and air cooled VWs, but that didn't make it any easier for me to find. It was cheap once I finally dug one up.
Will
SponsorHouse profile
Old 08-28-2005   #3 (permalink)
I had no problem getting one at the local Sears for less than 10 bucks. However it was the last one they had. Good luck.
Jared26 is offline   Reply With Quote
Old 08-28-2005   #4 (permalink)
Favorite Bike: 2002 Triumph Speed Four
Other Motorcycle: 1981 Kawi KZ1000 cafe
Extra Motorcycle: 2002 Suzuki SV650
tool'17mm hex 'drain plug tool'
$8.99
Cut off with dremel, put in 17mm socket on torque wrench, that's what I did.
SVRider is offline   Reply With Quote
Old 08-28-2005   #5 (permalink)
OK, thanks all.
I found what I needed at the local AutoZone, OEM Industrial 1/2" drive metric hex bit set, package includes 12, 14 & 17mm bits, $7.99 + tax. What a deal.
Ken :-D
Front Wheel Removal?? Ninjaboy Triumph SuperSports 5 07-08-2007 02:57 PM
size of front wheel axil/spindle allen bolt 2000 st? stwanted Sprint Forum 4 03-20-2007 05:33 PM
front wheel removal xlr8r Triumph SuperSports 19 04-21-2006 06:26 PM
Front Wheel Removal on '03 S3 MCSP3 Speed Triple Forum 1 07-29-2005 03:42 PM
Front Wheel Removal DahktahJay Sprint Forum 6 07-10-2005 08:05 AM
