Astro-whatever:
No, the kit comes with a set of handlebar clamps that grab onto the fork tubes. No drilling of the top clamp is required.
I didn't want to drill my top clamp. Until I finally broke down and bought the kit, I was also looking for a tt600 or S4 top triple clamp on ebay to grind off the unnecessary bits and drill. The I planned to put the modded top triple on top of the bike's top triple, thus giving me slightly raised tubular bar mounts. I didn't go this route, but it strikes me as a way to build your own without harming your stock clamp.
Banda:
The kit came with:
Ungodly wide LSL aluminum bar,
Bar clamps that grab onto fork tubes,
Spiegler brake line w/adjustment jig and five crush washers, to replace too-short stock line,
Relocation bracket for brake fluid reservoir,
Rather spartan instructions.
It cost me 300 shipped from streetfighters-usa.
I am using the stock clutch cable, though I had to re-route it. I may fiddle with that some more, but the right-angle at the lever end kind of forces me into only a couple of possibilities with my narrow bar. Keep in mind that the bar I added is a bit shorter than the ape-hanger LSL puts in the kit. It's very similar to, say, an '02 Speed Triple bar.
I added a set of bar-end weights for aesthetics, though vibration is no worse than before with the clip-ons.
I still have to clean some things up, though.
