Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 08-08-2005   #1 (permalink)
Can anyone recommend a rear hugger for a 2000 tt600?
MercuryMan76 is offline   Reply With Quote
Old 08-08-2005   #2 (permalink)
hey dude i have got a triumph hugger on my tt it is in carbon fibre and looks the nuts really close to the tyre cost £90 fitted so it would be around $160 i guess but well worth it to stop gettin all that ***** on your shock
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 08-08-2005   #3 (permalink)
hinckleyboy, did you get the hugger from the dealership or have you seen them online anywhere? $160 doesn't seem bad and you're definitely right, i want to keep all the ***** from building up on my swingarm and shock.
Old 08-08-2005   #4 (permalink)
I paid $150 for the Triumph hugger for my S4. It's made out of plastic with a fake carbon fiber imprint on the outside surface. It works fine except that the bracket that goes under the rubber swing arm chain guard lifts the rubber up so that the chain causes undue wear. I cut off that bracket and it still holds on tight by the other attachments.
I don't know of any other hugger for the S4 (or the TT600?).
Dave
Dave
DaveC is offline   Reply With Quote
Old 08-09-2005   #5 (permalink)
Rik
Favorite Bike: Speed Four
Rik's Avatar
ERMAX & SECDEM both do colour matched huggers fot TT600/S4
I can't recomend the Triumph fake Carbon Fibre/Fiber one as mine deformed after 15 months to the point that when I had a new tyre fitted it was touching so had to raise the hugger with washers to stop it fouling.
Rik is offline   Reply With Quote
Old 08-09-2005   #6 (permalink)
I had the Triumph carbon one on mine. looked great and the best bit was the dirt doesn't show up. The yellow one on my D650 gets filthy the second a drop of rain falls.
plagued is offline   Reply With Quote
Old 08-10-2005   #7 (permalink)
Dave
I got the triumph fake CF hugger and I'm gonna cut that bracket off. I'm sick and tired of the noise and people telling me that my chain sounds like it's gonna snap.
TTsixxer is offline   Reply With Quote
Old 08-10-2005   #8 (permalink)
TTsixxer,
I don't think you should be hearing anything. If you do, it may be that the rubber protector has worn through and the chain may be rubbing on the swingarm.
Dave
Dave
Old 08-10-2005   #9 (permalink)
I have the Triumph hugger too.
The chain wore through the rubber and made a hell of a racket rubbing on the hugger bracket.
I cut that piece of bracket off, and replaced the rubber.
I was able to do it without removal of the swing arm.
It took a little patience (cussing/swearing) , but the rubber strip is pretty flexible. haven't experienced any problems after 1500 miles
smokestack is offline   Reply With Quote
Old 08-11-2005   #10 (permalink)
HI AGAIN PROBABLY NOT MUCH USE BUT THERE IS A HUGGER ON EBAY (BRITISH ONE ) HE SAYS HE WILL POST WORLDWIDE
looking for a rear hugger PROMOD1385 Speed Triple Forum 10 05-13-2007 01:49 PM
tt600 rear hugger jhintw Triumph SuperSports 5 09-18-2006 08:13 AM
TT600 hugger pyro_ Triumph SuperSports 3 04-20-2006 09:47 AM
Rear Shock Suggestions Shorty Twins Talk 11 02-03-2006 09:25 AM
