BikeBandit
Old 07-24-2005   #1 (permalink)
anybody out there in triumph land have inverted forks fitted to an S4/TT600? Saw a really nice pair tonigh on a Motto Guzzi, ohlins everything, brembro brakes, man did it look nice(aka expensive as heck)
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
Joe275 is offline   Reply With Quote
Old 07-24-2005   #2 (permalink)
What performance difference is there between inverted forks and what comes stock on an S4? I see most larger displacement sport bikes with inverted forks but is there a reason why they have them and not the 600's?
Practice safe motorcycling. If you can't ride safe, Ride faster.
timyjimy is offline   Reply With Quote
Old 07-24-2005   #3 (permalink)
they flex less, which is an issue in turn 2 at Jerez but I'm not convinced there's any reason for them on the street other than the good looks.
thanks,
-Andrew
burgessa23 is offline   Reply With Quote
Old 07-24-2005   #4 (permalink)
i have been told that they flex less fore and aft but they also don't twist as easy. I have ridden CR250's with and without inverted forks and to be honest all the things they help, i never knew needed helping until i rode one :-D I think they are putting them on the bigger cruisers because they have more stability with higher weight. and of course, they do look bad a$$
Old 07-25-2005   #5 (permalink)
Inverted forks (shocks, etc...)also work better, because they have less unsprung weight than a conventional fork. I belive the tradeoff is more overall weight, which would slow steering, but I may be wrong about that. Again, would you ever notice the diference on the street???
:kck: I like that one.
[ This message was edited by: pokey on 2005-07-25 11:57 ]
http://forum.svrider.com/index.php?a...03;type=avatar
The reason you find yourself sitting on your nuts is that they're overly large.
pokey is offline   Reply With Quote
Old 07-29-2005   #6 (permalink)
Actually, except the Daytona 650's all, for 05 all the 600's got
inverted forks and radial brakes... I read an article a while back talking about inverted forks and in addition to the reduced unsprung weight, the stiffness is there to battle front-end chatter... something about making the fork and tire vibrate at different frequencies, and canceling each other out.
FullRunSilviaKs is offline   Reply With Quote
Old 07-29-2005   #7 (permalink)
Plus, inverted forks are newer, so your bike doesn't look dated or cheap. I'm sure it helps sales, but whether a regular rider would notice on the street or not remains to be seen. Since mfgrs source this stuff from Showa, Ohlins, etc, no doubt the ones with better quality internals would also be of the more modern/popular design (USD). So if you want to put top-spec forks on a bike, chances are good it will be an USD design.
Pittsburgh RAT Pack
www.pghratpack.com
garry is offline   Reply With Quote
Inverted Flux Wire Rim Topper DrewDesign007 Twins Technical Talk 8 01-25-2008 03:34 PM
Looking for F3 forks MAR Twins Technical Talk 19 10-01-2007 02:39 PM
'67 forks TomThomson Classic, Vintage & Veteran 3 02-28-2007 08:17 PM
MX forks on 06? jaak Tiger Chat 0 12-12-2006 09:37 AM
fitting inverted forks to an S4 FuryFour Triumph SuperSports 6 04-21-2006 09:31 AM
