valve clearance check. advice - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-17-2010, 09:50 AM   #1 (permalink)
Favourite Bike: Speed Four
Ok folks, i am hoping to be doing the valve clearance check on my 2003 speed four on saturday morning.
Is there any advice, hints, tips or you need this! that i need to know?
Andy-Brad is offline   Reply With Quote
Old 03-21-2010, 03:40 PM   #2 (permalink)
be patient. double check everything. I take a sheet of paper and draw 4 identical circles on it in a row. these are your cylinders, number them if it helps you keep them in order. then i mark two lines for the exhaust valves and two lines for the intake. write your numbers on the corresponding spaces. i put a picture below in case you don't follow.
Agkistrodon "aka" billy badass
check out my sponsorhouse profile.
http://www.loopd.com/Members/texaspro/Home.aspx
Agkistrodon is offline   Reply With Quote
Old 03-22-2010, 09:52 AM   #3 (permalink)
what a ballache! got to get a shim for one valve as its just off bottom limit but christ...
Old 04-12-2010, 04:48 PM   #4 (permalink)
I totally agree, i had to change one shim on my TT when i checked em
The cam is a pain too, making sure the timing marks line up
winter of 69 is offline   Reply With Quote
Old 04-13-2010, 04:08 PM   #5 (permalink)
Favourite Bike: Triumph Speed Four
Other Motorcycle: Honda RS 250
Hey, just for future reference (just checked mine and din't need to adjust any) what size are the shims?
FART FYRA
pete2 is offline   Reply With Quote
Old 04-13-2010, 05:08 PM   #6 (permalink)
they will vary between valve to valve to ensure you get the correct tolerance. you cant just say there all 245 (mine was) you hae to disassemble, then reassemble, order, wait,dissassemble, fit, reassemble. thing jesus christ what a pain in the ass.
Old 04-14-2010, 01:02 AM   #7 (permalink)
Uhhhhh.... In diameter, not thickness
FART FYRA
Old 04-14-2010, 06:21 AM   #8 (permalink)
i'll check tonight for ya. there very similar to kawa ones and i reckon a sizi one would fit but its not right!
Old 04-14-2010, 09:23 AM   #9 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
Diameter is= 7.48mm. Just double checked with my shiny new caliper.In reference to the "order, wait, dissasemble, reassemble" method. Check HOTCAMS website. They sell shim kits with most of the sizes we would need. Unfortunately no kit for Triumphs but if you know the diameter (frist sentece) you can order the correct sizes. I have been meaning to buy one because it beats the hell out of driving to the dealers to buy/trade shims just haven't done it yet. Plus you'll be able to use them on other bikes in the future.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 04-14-2010, 12:13 PM   #10 (permalink)
Originally Posted by kubbie View Post
.... shim kits with most of the sizes we would need. Unfortunately no kit for Triumphs but if you know the diameter (frist sentece) you can order the correct sizes.
Just why I asked! TY
FART FYRA
Valve clearance check conundrum Lion Twins Technical Talk 11 01-21-2010 09:29 PM
ST1050 Valve clearance check danall Sprint Forum 3 11-20-2008 09:00 PM
Time to check the valve clearance ohiorider Twins Technical Talk 2 09-19-2008 09:01 PM
Rocker arm clearance/valve clearance... whatever you want to call it. double-d Club Cafe' 4 04-04-2008 10:41 AM
Valve Clearance Advice rodmo1 Hinckley Classic Triples 25 03-06-2007 05:58 PM
