Start from cold and get it good and hot. I don't know for sure if the fan has to come on, but if you get it warm enough for the fan, then you can be sure it's warm enough. Then let it cool clear down. Once it has cooled all the way down to the point it goes through its cold start routine with an enriched mixture, you have gone through a heat cycle.
Will
SponsorHouse profile
