Integrated LED tail lamp and ODO issue _ Daytona 600 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-12-2010, 03:07 PM   #1 (permalink)
Favourite Bike: MV Agusta F4 CC
MrFast4Ward's Avatar
I installed a neat integrated LED tail lamp yesterday and today I noticed the ODO is not reading anything (0mph, and mileage not recording). I'm assuming the ground for the signal is what is causing this since it's not plugged to anything. Have you run into this and how do you fix it?
This is in a 2004 Daytona 600
Thank you in advance
MrFast4Ward is offline   Reply With Quote
Old 03-12-2010, 07:19 PM   #2 (permalink)
Update: I just jumped on it for lunch this afternoon and the ODO and Speedo were fine... weird.
Old 03-12-2010, 07:23 PM   #3 (permalink)
Favourite Bike: Speed Four
spank86's Avatar
TBH from what you've said I'd be inclined to look for a loose connection that you might have jogged when you were working.
I mean if the tail light is working as it should then you shouldn't be able to do much that will stop the clocks working. Would have thought the two are completely separate apart from at the battery.
That or if they go off again just unplug the tail light completely and see if they come back on... If not you'll know for definite it's not that.
spank86 is offline   Reply With Quote
integrated tail lights 02trumpet Twins Talk 3 03-29-2009 02:46 AM
integrated led tail lights? redninja Club Cafe' 13 01-03-2008 12:54 AM
integrated tail light... mongo Speed Triple Forum 1 03-12-2007 07:38 AM
Integrated Tail Lights 3xdope The Rocket Science Forum 1 11-13-2006 04:03 AM
Integrated Tail Light jmorrow84 Sprint Forum 1 07-24-2006 07:50 PM
