Any idea if an ignition switch form a srint ST would fit a speed four?
Anyone have the wiring diagrams for these two so I could check if they are interchangeable?
Use BikeBandit and reference the fiche for each model (or others) and see if the numbers match.
Recognize when you say Sprint ST, there are at least three generations, so need to be a bit more specific.
