You say tapping does not correspond to wheel speed, but the chain and wheel speed are directly related. Is it engine speed related? If so, forget about the (final drive) chain.
Could be chain rubbing on the stand or something. As you accelerate the slack part of the chain will be at the bottom. Holding a speed it will be even(ish) top and bottom. Under engine braking the slack part moves to the top. May just be too much slack in the chain or an unevenly worn chain.
Could also be a stiff link, but I don't really understand how this would only show in acceleration.
Another thing to check are the sprockets and alignment of rear wheel (make sure it is straight to the frame).
Paul
It's a fine line between a hobby and an obsession
