tt600 won't start - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-03-2010, 03:14 AM   #1 (permalink)
Favourite Bike: anything not japanese
Other Motorcycle: TT600
tt600 won't start
i have a tt with a little over 20,000 miles. the other day i went for a ride to the local theater. after the movie i came out and went to start my bike. i had to hit the ignition button about three times before the bike would start. when it did start i drove it across the parking lot to get food then went to leave and the bike wouldnt start. about a week before this happened i started noticing some weird symptoms. a lot of backfiring when speeding up and slowing down, the engine would die when accelerating quickly (such as getting on the freeway). I'm assuming the prob is not battery, fuses, alternator, or spark plugs, because if it was my bike wouldn't have started at all after the theater. correct? i'm guessing its one of 3 things fuel filter, fuel pump, or fuel injectors.
if any body could help me trouble shoot this issue that would be great. im leaning twords it being the fuel pump is there any way i can check this without disassembling my bike
thanks
dutch85 is offline   Reply With Quote
Old 03-03-2010, 03:29 AM   #2 (permalink)
Favourite Bike: Speed Four
Other Motorcycle: NX250
When you turn on the ignition can you hear the fuel pump prime?
yipes_stripes is offline   Reply With Quote
Old 03-03-2010, 03:37 AM   #3 (permalink)
i believe so,but i did noticed when i turned the ignition back to the off position it sounded kinda weird like there was a small motor trying to move something jammed. don't know if it made that sound before cuz i usually turn off the bike in loud areas with my helmet on, and the sound is kinda faint.
thanks for your reply
Old 03-03-2010, 06:21 AM   #4 (permalink)
Favourite Bike: CB550K/Velorex
Other Motorcycle: Speed Four
A small motor? If you're pressing the ignition button and hearing a little motor go clickety clack then you're not getting enough power from the battery. Have you tried eliminating a bad battery from the list of possibilities?
showmetheway428 is offline   Reply With Quote
Old 03-03-2010, 11:10 AM   #5 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
The one thing that comes to mind is the IACV
It happened to me at Daytona during Biketober fest, one of the four vacuum hoses going to the IACV split. My bike was hard to start. Idled really low when it did finally start. And popped /backfired/acted like it was missing sometimes. Generally ran like crap.
Let us know what you find out.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 03-04-2010, 01:56 AM   #6 (permalink)
ya its not the battery cuz the engine tries to start.(although i prob need to charge the bat. soon from trying to start it so many times) and my friend sprayed some "quick start" stuff in the engine and it came really close to starting but still wouldn't start.
Old 03-04-2010, 01:57 AM   #7 (permalink)
thanks i will check the iacv if i can locate it lol
Old 03-04-2010, 08:53 AM   #8 (permalink)
kubbie's Avatar
its behind #1 cylinder (left-hand side) looks like an octopus. what split on mine were the little rubber connectors on the ends of the hoses. total of 4 hoses, 2 connectors per hose.
a hose goes to the intake tract of each cylinder
kubbie
Old 03-05-2010, 02:22 AM   #9 (permalink)
so here is an up date, my problem is not solved yet but i checked the IACV is fine. i poped off my all the way and took the brass thing with the pump and filter attached and every thing looks good. i plugged my fuel pump in while it was out of the tank and it is definitely priming up when i turn the key. does this factor insure that my pump is perfectly fine and that is not the cause to my issue? also i have a new filter i have yet to install but could my filter really be that dirty? to the point where my bike cant start cuz of it.
Old 03-07-2010, 12:53 AM   #10 (permalink)
bump for more help please
TT600 won't start - any suggestions emelcee Triumph SuperSports 7 04-17-2009 01:39 PM
TT600 - Refuses to start thehyperintelligentslug Triumph SuperSports 20 08-14-2008 10:31 AM
TT600 wont start rob-cyn Triumph SuperSports 8 05-28-2007 12:00 AM
Please Help again...update on my tt600 doesn't/won't start mosula Triumph SuperSports 0 08-25-2005 03:06 PM
Help my tt600 won't start up mosula Triumph SuperSports 4 08-10-2005 04:41 PM
