Foot breaklight not working - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-02-2010, 10:08 AM   #1 (permalink)
Favourite Bike: Triumph 675
Other Motorcycle: Triumph TT600
Hey guys
(TT600)
Its time to take out the bike for its first run of the year.
Problem is that ill have to take it for its inspection where they check if the bike is roadlegal or not.
Problem is that the break light on the foot break is not turning on.
with the hand break it works.
im guessing the problem came up when i changed the back tire last year.
Can i have damaged something?
jojye is offline   Reply With Quote
Old 03-02-2010, 10:31 AM   #2 (permalink)
Favourite Bike: MV 750 Sport 1972
Other Motorcycle: tiger 1050
Extra Motorcycle: Moto Guzzi Falcone
The problem is likely to be a faulty switch, or a loose connector. Either way, it should be easy to locate and fix. Remove the seat and look at the wires that go to the rear light. Check all the connections. If all seems ok, look at the switch itself. This will be behind the heel guard, or somewhere near the pedal. pull off the rubber boot, and check the wires. If all seems ok, then get out the multimeter, and check out the switch.
M.Guy.Vig. is offline   Reply With Quote
Old 03-02-2010, 09:25 PM   #3 (permalink)
Favourite Bike: CB550K/Velorex
Other Motorcycle: Speed Four
It's probably not the switch itself, but the mechanism that it operates on. At the right peg is an assembly with a heelguard/footpeg and the brake assembly that connects to the rear brake fluid reservoir. You'll notice that a wire does indeed connect behind it and to a switch. The switch operates by having a pin pulled by this long double sided hook when the rear pedal is depressed. I have the same problem since at some point I disassembled that part to replace the peg.
I'd take a look at the physical mechanism first, find the hook and pull on it yourself. If your brakelight lights up, its nothing electrical and just a matter of the hook. Then it's up to you if you want to actually fix it to stock or figure a way to manually modulate it independent of the brake lever.
showmetheway428 is offline   Reply With Quote
Old 03-03-2010, 02:52 PM   #4 (permalink)
The "hook" is actually a spring. True, it pulls on a sliding pin inside the switch. It is possible the pin is frozen. Spray electrical contact cleaner into the switch to clean it then some WD/40 or equivalent to lubricate. If you can activate the light by manually pulling on the "hook" then it is a matter of adjustment.
ntmid8or is offline   Reply With Quote
Low Beams Not Working Ironhidetx Sprint Forum 2 06-23-2009 10:38 AM
A project I've been working on Shawn Biker Hang-Out 13 02-29-2008 02:24 AM
Working Out....... Lee Biker Hang-Out 52 02-18-2008 05:35 PM
Breaklight and Turn signal help FunCrusherPlus Club Cafe' 6 10-07-2007 03:54 PM
00 St oil light not working KevinH Sprint Forum 0 04-27-2006 06:02 PM
