home made fender eliminator - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-28-2010, 12:48 AM   #1 (permalink)
Favourite Bike: 05 Speed Four
snuffcityrider's Avatar
Other Motorcycle: 2010 Gold Wing
My best friend did this mod for me. Got rid of the fender and brought the turnsignals closer together.
snuffcityrider is offline   Reply With Quote
Old 02-28-2010, 12:59 AM   #2 (permalink)
Old 05-03-2010, 10:17 PM   #3 (permalink)
Favourite Bike: 2003 Speed 4
divino's Avatar
can we get a how to?
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles."~ Hunter S. Thompson
divino is offline   Reply With Quote
Old 05-04-2010, 02:05 AM   #4 (permalink)
Favourite Bike: Ones with two wheels
Mista Bob's Avatar
Other Motorcycle: '01 TT600
Aww man, looks way better than mine.
Mine just looks ghetto.
Mista Bob is offline   Reply With Quote
Old 05-04-2010, 03:05 AM   #5 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
It looks like he cut off the mudguard toward the top, and fastened the license plate to the subframe. Relatively doable with a hacksaw or tin snips and a drill.
The other option for the more mechanically inclined is to build an "L" bracket out of sheet metal or aluminum sheet and screw/bolt it to the undertail or the subframe. That also allows you to mount aftermarket turn signals if you bend in the sides of the bracket.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 05-04-2010, 10:43 PM   #6 (permalink)
I sawed the fender off and sanded it smooth. The turn signals were mounted with "L" brackets that you can pick up at any hardware store. I was able to bring the turn signals in and forward so they don't stick out as much. I would imagine that you could mount just about any signals with the brackets. The license plate was mounted with a small license plate bracket and fastened to the fender. A coulple of hours and less than $10 worth of parts. The kits I've seen that achieve basically the same thing cost $150. Basically did exactly what Bombfactory said, I just bought the L brackets instead of fabricating them.
Old 05-09-2010, 11:20 AM   #7 (permalink)
Favourite Bike: 04 Daytona 600
Other Motorcycle: 96 Honda CBR600 F3
can we get some better pics?? I'd really like to do this. Thanks!
aries1098 is offline   Reply With Quote
Old 05-11-2010, 11:10 PM   #8 (permalink)
I'll try and take some close up pics tomorrow.
Old 05-14-2010, 07:16 PM   #9 (permalink)
upclose pics of mod
I intend to make something to cover up the L brackets, you can't see them unless you squat down right next to the bike
Old 05-14-2010, 07:17 PM   #10 (permalink)
Home made fender eliminator blutrip99 Speed Triple Forum 19 02-09-2010 01:47 PM
Home made 2008 Fender Eliminator! ryushi Speed Triple Forum 4 02-27-2009 02:01 PM
Rear fender eliminator plan using stock sub-fender cshell Speed Triple Forum 2 01-14-2009 03:44 PM
Home Made Fender Eliminator bobmcduff Speed Triple Forum 9 04-27-2008 12:16 AM
My home made fender eliminator Black Phantom Speed Triple Forum 9 01-22-2008 07:57 PM
