Case of the dissapearing coolant (01 TT600) - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports SportbikeTrackGearNew Bonneville
Old 02-25-2010, 08:53 PM   #1 (permalink)
Favourite Bike: Ones with two wheels
Mista Bob's Avatar
Other Motorcycle: '01 TT600
I'm at a bit of a loss here....
The coolant in the reservoir seems to disappear somewhat quickly over time.
I will put it just under the full mark and then 1-2 weeks of riding later it will be below the empty mark.
There is no puddles under the bike where ever I park it, so I would think it's not just a straight up leak in the water cooling system.
What could be causing this?
Mista Bob is offline   Reply With Quote
Old 02-25-2010, 09:23 PM   #2 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
A leaking head gasket comes to mind. Its been a while since I looked at the gasket, but in theory it can leak around the top of the cylinder sleeve. Its a thin ring that does all the work and under pressure let water into the cylinder which instantly turns into steam then out the tailpipe.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 02-25-2010, 09:32 PM   #3 (permalink)
Mista Bob's Avatar
That was one possibility that was brought up when discussed with the shop where I bought it.
But the bike doesn't have any white smoke coming out of it as far as I know (I'm usually looking forwards when riding ).
Could it possibly leak out the side of the engine slowly rather then into the combustion chamber?
Old 02-26-2010, 08:56 AM   #4 (permalink)
I have a Speed4 similar issue, though one time I had smoke out of the tailpipe but the dealer looked it over and gave it a clean bill of health. Makes me worry as my warranty is up next month, is there a test that I can have them do to see if there is a small leak in the head gasket?
http://www.triumphrat.net/triumph-su...rning-oil.html
We're in Italy and occasionally we get a dumbass Italian who decides to do something heroic and it all goes pear-shaped. -Colin Edwards
skiTTles is offline   Reply With Quote
Old 02-26-2010, 09:11 AM   #5 (permalink)
Favourite Bike: 1996 916
malott442's Avatar
Other Motorcycle: 2002 Triumph Daytona CE
Extra Motorcycle: 1998 Buell S1W
Did you inspect your coolant res. for cracks? Also,another idea may be to rubber band a bag over the end of the vent tube for the res. See if it is simply overfilling, most likely due to a small bubble in the coolant system. The coolant will only leak out during a ride, I had that happen to me on my Triple.
malott442 is offline   Reply With Quote
Old 02-26-2010, 11:52 AM   #6 (permalink)
I'll tell you that after a ride I can smell cooked coolant. But I can't see any anywhere.
Old 02-26-2010, 02:31 PM   #7 (permalink)
Favourite Bike: 00 TT600
Other Motorcycle: 08 Ninja 650R (Bride's)
Extra Motorcycle: 75 Honda CL360
If it's leaking coolant into the cylinder, that spark plug will usually be really clean...almost new looking, the porcelain (sp?) will be white.
My 2000 had pinholes in the upper radiator hose connection. It showed no signs of a leak, but I kept getting air in the system no matter how many times I bled/burped it. Then it would puke coolant while riding.
Have some one pressure test the cooling system.
Good luck, these gremlins can make you pull your hair out!
Scott
swassermann is offline   Reply With Quote
Old 02-27-2010, 02:27 PM   #8 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
Using the forum search will bring up more information:
http://www.triumphrat.net/triumph-su...e-coolant.html
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is online now   Reply With Quote
Crank Case / Primary Chain Case - Seals Help Will71bonneville Classic, Vintage & Veteran 8 02-12-2010 02:48 PM
Newly naked TT600 coolant bottle relocation tiriana Triumph SuperSports 6 10-06-2008 03:08 PM
TT600 filling coolant , can you cheat ? Dingle Triumph SuperSports 2 01-23-2007 12:22 PM
dissapearing posts retrobiker Classic, Vintage & Veteran 4 10-16-2006 09:29 AM
HELP!!! TT600 leaking coolant jhintw Triumph SuperSports 14 09-18-2006 01:06 AM
