Headstock bolt/mount sat nav - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearNew BonnevilleMotorcycle.comOntario Tourism
Old 02-21-2010, 02:39 PM   #1 (permalink)
Newbie
Hi, i am trying to find best way of mounting a sat nav unit on my tt600 ahead of a euro trip later this year.
I have a recommendation that the headtock bolt can be machined to accept a thread in the top of it, to mount said unit.
Is the headstock bolt easy to take out? - what drops off i i undo it? and are there any other clever options anyone has successfully used to mount a unit. the usual round clamps have no space on the handlebars
Cheers
D
D916 is offline   Reply With Quote
Old 02-21-2010, 03:46 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I'm not sure what you mean by "headstock bolt." There really isn't a headstock bolt, aside from the actual bolt that runs through the headstock, which cannot be drilled into, nor should be.
Are you talking about the top triple clamp acorn nut in the center of the top clamp? If that is the case, I don't recommend drilling and tapping it, as vibration could crack it.
I'm sure there have been people who've modified something on the triple clamp or clipons to mount a navigation unit, but is there a reason why you don't build a bracket coming off the front fuel tank mount or off the fuel cap? Maybe even a bracket that uses the instrument panel bracket-to-frame mounting holes?
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
headstock bearings simzrx Speed Triple Forum 1 07-31-2008 10:15 PM
engine mount bolt locations oldebonnie Classic, Vintage & Veteran 4 01-09-2007 07:05 PM
HEADSTOCK TOOL nyburner Speed Triple Forum 7 04-25-2006 09:44 PM
Headstock Bearings? HorseWhisperer Twins Talk 1 10-24-2005 03:26 PM
