16T front sprocket? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 02-19-2010, 09:54 PM   #1 (permalink)
Favourite Bike: Speed Four
Other Motorcycle: NX250
16T front sprocket?
OK. - I am currently running 15/45 (came stock that way) and had to replace my rub strip after 5500 miles. After another 2000 miles, I am well on my way to another replacement. I have seen a few of you go 47 in the back, but, I don't want to replace my chain and was thinking about just upping it one tooth in the front to lift the chain a little higher. Bad idea? Anyone have any opinions? I am all ears...
yipes_stripes is offline   Reply With Quote
Old 02-19-2010, 09:59 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
It depends on what you require from the engine when riding. A 15/45 sprocket gives a 3:1 ratio, while a 16/45 will give you a higher ration at 2.81:1. This means you will have less torque at the rear wheel, and the engine will turn at a slower rpm for the same speed as a 15/45 setup. This may mean you will spend more time in lower gears to get up to speed or when cruising around, but it doesn't hurt anything. You may see slightly better fuel economy if you do a lot of highway riding. Technically speaking, you will be able to hit a higher top speed before bouncing off the rev limiter, but it will take more time and a longer stretch of road to get there than a lower gear ratio (assuming aerodynamics are not overpowering).
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 02-20-2010, 12:57 PM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I actually doubt a taller gear ratio (meaning a 16 tooth front sprocket) will get you better fuel mileage. I saw no change going from the stock ratios to shorter gearing, making it unlikely the relatively small change in rpm at any given speed will have a noticeable impact. It's how heavy your right hoof is on the throttle which makes all the difference for fuel economy.
If anything, I would expect the fuel mileage to go down, since you will have to use more throttle at any given speed due to engine's torque curve and the lower engine speed. The other problem you will have going to an even taller setup is bogging off the line. You will have to slip the clutch more, and a slipping clutch isn't a happy clutch.
Will
SponsorHouse profile
Old 02-22-2010, 04:48 PM   #4 (permalink)
Thanks for the replies. Yeah - I guess I will just have to see what I think. Really, the biggest issue I may have is what Will pointed out - when commuting, starting from stop at all the lights, what will it feel like from a complete stop. I will give it a shot and post what I think. If 16/45 is not my think, I will just spring for a new chain and a 47 or 48 rear (16/48 is same ratio as stock).
Bomb Factory and Will - you both contribute a ton here. Thanks!
Old 03-18-2010, 05:33 PM   #5 (permalink)
Thought I would report back. I don't have to slip the clutch at all, and my low rpm jerkiness (that annoying drive train lash at ~2500 rpm, or ~20mph) is no longer an annoyance with the new gearing. I actually like it. I do think that when my chain is worn out I will up the rear and run 16-47, but the 16-45 works fine.
Old 03-22-2010, 04:31 PM   #6 (permalink)
Will's Avatar
Good news. We all learned something. Thank for telling us how your experiment worked.
Will
Non std front sprocket. Why? Eyore Sprint Forum 12 11-20-2009 06:24 AM
15t front sprocket mr hyde Maintenance & Workshop Talk 2 04-01-2009 07:25 PM
front sprocket nut starfighter Sprint Forum 2 03-09-2009 04:58 PM
Going to and 18T Front Sprocket Calliway Sprint Forum 44 10-22-2008 09:42 AM
Front Sprocket Bushwhacker Hinckley Classic Triples 3 09-15-2005 03:31 PM
