loping idle and diming lights??? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-12-2010, 02:54 AM   #1 (permalink)
my tt600 has a healthy lope in the idle when warm, bikes stock besides pipe and lights slightly dim when the bikes reved???
ixc450 is offline   Reply With Quote
Old 02-12-2010, 02:00 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I'm confused by what you mean by a "healthy lope." If it is healthy, there is no problem. What rpm does the engine idle at when cold, warming up, and when at running temp?
To troubleshoot the dimming lights, I'd first take some DC volt readings at the battery terminals with the engine off, idling, and raising the rpm up to 5K.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 02-12-2010, 05:19 PM   #3 (permalink)
i jus mentioned the lope thinking it was coralated to the lights dimming when revved....
cold=2200
warm up=1800
running temp=1000
Old 02-12-2010, 08:48 PM   #4 (permalink)
The rpm values look normal. It should idle between 1k and 1,300, although the tach is not perfectly accurate. I'd say engine rpm isn't the issue, but you could have a charging or battery issue. The voltage readings will give you a better idea.
Old 02-13-2010, 05:02 AM   #5 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
My 2000 has from day one had a lope to its idle. I just write it off as a "radical street cam".
And yes I do know the thing has two cams.
Do the lights get bright and stay that way when you pick the revs up a little. If so I say everything is OK. But do keep an eye on the charging output.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 02-13-2010, 07:50 PM   #6 (permalink)
yea i lead ppl on that it has some big lumpy cams too...illl check the battery voltage but i can let the bike set for weeks at a time and it cranks over and fires right up in 12degree wheather up here in indiana i wasnt to worried bout it but i thought it might be a sign of something bout to go bad
thanks for the input
Tail lights out - Brake lights work crescen7 Daytona Deliberations 7 09-02-2008 10:00 AM
Bike's Cold Idle is low, warmed up idle is OK GleaminTwin Classic, Vintage & Veteran 5 05-25-2008 10:24 PM
D&Ds Engine sputtering and dying (taking off from lights) and Idle RPM setting?? Hammerhead Twins Talk 2 06-11-2005 12:13 PM
Lights dimming in idle Maintenance & Workshop Talk 5 09-29-2004 06:43 PM
Lights dimming in idle Hinckley Classic Triples 4 09-29-2004 08:18 AM
