TT 600 bike setups - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comHonda Powersports Ontario Tourism
Old 02-11-2010, 05:40 PM   #1 (permalink)
TT 600 bike setups
i jus got my 2000 tt and i were wondering what sprokets u all use and what mapping system/tuners u have used to cure the tt of its bogs and stutters im liking the tuneboy whats your opions and comments
thanks
ixc450 is offline   Reply With Quote
Old 02-12-2010, 03:56 AM   #2 (permalink)
Favourite Bike: duh my TT
Other Motorcycle: Sv650
Extra Motorcycle: f4i
sprockets depends on what you are doing but I think the 15(14)?/47 is solid
and the tor map is good too from the dealer.. if you are having trouble with bogging issues then downshift and be higher in your rpms
Matt
AFM #940
2001 Racing Yellow TT600
yakoo11 is offline   Reply With Quote
Old 02-16-2010, 11:21 AM   #3 (permalink)
Favourite Bike: TT600 -It's my first bike
ddresser13's Avatar
I'm in the same boat......I want to upgrade the chain and sprockets and would like to know for more torque what I need. I've read numerous threads without any definition on what combo gives you top speed and what gives you more torque
-Jinx (2001 Triumph TT600)
"People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs”
ddresser13 is offline   Reply With Quote
Old 02-19-2010, 02:15 PM   #4 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
The funny thing is the usual combos - 15/47 or 15/49 - raise the engine revs over stock, but also raise the top speed. The reason is top speed is limited by aerodynamics more than revs, so if you have just a few more revs at the top, it make enough more power to make the bike just a little faster as well as a little quicker.
Will
SponsorHouse profile
Old 02-19-2010, 02:51 PM   #5 (permalink)
Sprocket setup
I run the 15/47 setup with a 520 chain. The 15 tooth in the front helps keep the chain off the rubbing block on the swingarm. I weigh 220 pounds so this helps with the low end pull(torque) off the line. It still allows a top speed over 150 mph.
ntmid8or is offline   Reply With Quote
Old 02-22-2010, 10:18 AM   #6 (permalink)
ddresser13's Avatar
That's perfect! Thanks guys! I will be looking for a set today.
Old 02-22-2010, 01:19 PM   #7 (permalink)
I got my setup from an Ebay store called Sum Of All Parts. $140 shipped and I received the package in two days. Don't forget to check the condition(backlash) of the rubber cush drive while you're at it. Also get a new sprocket nut and tab washer.
Old 02-22-2010, 01:38 PM   #8 (permalink)
Will's Avatar
Good point about the cush drive. I replaced it on my 2000 TT600, and it made a huge difference in how the bike felt off the line.
Will
Old 02-22-2010, 04:24 PM   #9 (permalink)
ddresser13's Avatar
Nice,
Thanks guys. Ebay here I come! Wife will be pissed Makes it that much sweeter. haha
Old 02-22-2010, 04:38 PM   #10 (permalink)
ddresser13's Avatar
Which did you get? They have multiple applications but nothin that has a TT600 in the description. Sorry for all the idiot questions, I just don't want to mess up.
Proven Setups for Hinckley Classics - Carb Jets, Pipes, Airbox, Cams, etc. BadMouth Maintenance Tips and Tricks for the T3 Classics 86 02-08-2012 12:23 AM
HP and Torque #'s with different exhaust setups 09Striple Street Triple Forum 9 09-01-2009 07:07 PM
has the 855-955 thing been sorted out yet? looking for proven setups oil-spitn-rat Hinckley Classic Triples 2 03-04-2008 09:34 PM
How about a member list of tuning setups? dazco Twins Talk 9 07-28-2005 08:51 PM
possible setups Maintenance & Workshop Talk 11 09-01-2003 04:42 PM
