d600 tt600/speed 4 fuel pump swap? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-11-2010, 10:04 PM   #1 (permalink)
Newbie
yes / no?
i have read conflicting info, and i have seen single and double outlet pumps for sale as daytona pumps
i have rebuilt a few tt600/s4 and i just picked up a complete - minus fuel pump and gauges - d6 engine with harness etc etc
need to know if my tt/s4 pump will work or not, or if i can mod it to work.
mcguirk is offline   Reply With Quote
Old 01-12-2010, 02:01 AM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
It depends on the production date/VIN of the motorcycle. If the Daytona has duel fuel lines, an S4 or TT600 fuel pump with duel lines is interchangeable; they are the same pump. If it is a single fuel line pump, a single line S4 pump is interchangeable; they too are the same pump as D600/650. For your info, at least from what I know, they never made a TT600 with a single line pump.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 01-12-2010, 02:04 AM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
The electric parts of the pump might be the same. I don't know. The outlets are different from each other. TT600s all used the same two outlet configuration, while later bikes used a single outlet similar to what is now used on Kiehin injected bikes. A few of the latest model S4s also used the later style configuration even though they were still Sagem injected. This is what I know, and it may not be absolutely correct. The best thing to do is inspect your injection system to see what the fuel lines are like, and use their configuration to decide which style of fuel pump you need.
Will
SponsorHouse profile
Old 01-12-2010, 11:51 AM   #4 (permalink)
Newbie
well that solves it pretty much.
thanks guys
HELP! TT600 fuel pump relay clicking on/off rapidly! ttwill Triumph SuperSports 6 09-03-2009 05:26 PM
Quick Swap List: D600 to TT600 waxyourboard Triumph SuperSports 17 09-10-2008 02:29 PM
D600 can on a TT600? MickyC Triumph SuperSports 3 05-10-2007 04:59 AM
Top speed of stock S4,TT600 & D600? Serious_Dave Triumph SuperSports 26 12-20-2003 02:10 PM
