Tt 600 Engine stop running. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-29-2009, 09:12 AM   #1 (permalink)
Hi there for 1 more time.
I had a problem with my bike.At low rpms the bike did not hear well.
I think the right word is stalling.
I went at the triumph dealership for a service.He told me that the gas was not good and that he found 1 littre of water at the gas tank.He told me that he cleaned the injections i think too.
He change oil,the 4 spark plugs too.
This was before 3 days ago.
Now i am at a trip in a town with lot of traffic and i have a problem.
When the temperatures goes high around 104 C the cooling fan kicks on and the engines stops...What is happening guys?what should i do?
I saw that the expansion cooling tank(the white one at the left side of the bike) was empty.I went at a shop and bought some coollant mixture and filled it up till the max mark.
I turned on the engine and let the temp goes up.Again at 104 c and when the cooling fan is starting the engine is turning off herself.
Please tell me what to do because i dont know a triumph dealer here and i ama afraid that the bike might have a fault.
Sorry for my bad english guys!
Please help the situation here!!
Thnsk a lot!
isaias1983 is offline   Reply With Quote
Old 12-29-2009, 12:01 PM   #2 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
My best guess is to check the charging system first. If it is not working at its best the electrical load of the fan can stall the engine. My TT would stumble then run fine, my charging system is barely strong enough.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 12-29-2009, 06:56 PM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
The fan draws a lot of current, so make sure the battery terminal screws are tight. As Kubbie pointed out, a weak charging system can be problematic with the fan. Next time you are riding, watch the temperature gauge, and when you see the fan is going to turn on, raise the engine rpm with the clutch lever pulled in or transmission in neutral. This may stop the engine from stalling, at least until you can find a mechanic you trust.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 12-29-2009, 11:33 PM   #4 (permalink)
Favourite Bike: duh my TT
Other Motorcycle: Sv650
Extra Motorcycle: f4i
this
On super hot days the bike will want to stall when the fan comes on. electrical checks out ok so I just tend to keep an eye on it and blip the throttle right when the fan comes on
Matt
AFM #940
2001 Racing Yellow TT600
yakoo11 is offline   Reply With Quote
Old 12-30-2009, 04:27 AM   #5 (permalink)
mine was doing the same thang then it solved it self some how lol
criminaltactic1 is offline   Reply With Quote
Old 12-30-2009, 05:16 AM   #6 (permalink)
Thnks for the answers guys!
When u say charging system u mean the battery?What should i check exactly?I have the manual of tt600 so if someone has it tell me the page so i can find it!I am a little noob with motorcycles!
Is there any problem to burn the engine?The fan starts at 104 C and then goes down to 100 c so the engine does not have a problem right?
Thnsk again!
Merry christmas and a happy new year!
Old 12-30-2009, 10:22 AM   #7 (permalink)
kubbie's Avatar
isaias, yes I do mean the battery but also the stator (alternator) and the regulator/rectifier.
If you have the Triumph service manual chapter 15 will show you what these parts look like and where they are located. Unfortunately it doesn't show you how to test anything, at least I couldn't find it.
Decossee over in the Speed Triple forum has given a very detailed explaination of how the entire system works and how to fix it, and upgrades you can make to the system.
Try this:
http://www.triumphrat.net/speed-trip...r-upgrade.html
A little side note. The plug coming from the stator going into the main harness melted twice on my bike. Its located on top of the transmission and if its messed up can cause big headache trying to diagnose other problems.
kubbie
Old 12-30-2009, 10:36 AM   #8 (permalink)
Favourite Bike: Triumph Speed Four
Other Motorcycle: Honda RS 250
Might be a grounding problem too
FART FYRA
pete2 is offline   Reply With Quote
Ticket for running a stop sign TriumphTengu Biker Hang-Out 30 11-08-2009 05:49 AM
Proper Way To Stop Engine (?) Dan in Cibolo Twins Talk 39 08-06-2009 12:38 AM
Engine stall-out/Shut-off at stop light/stop sign??? jrelloway Daytona Deliberations 7 02-01-2008 03:16 PM
Engine Stop Switch oldndumb Sprint Forum 25 05-29-2007 08:58 PM
Engine will stop when riding in the rain Lainer Twins Technical Talk 31 01-03-2007 07:42 PM
