That is the secondary air injection system; it's an emissions system that injects extra clean oxygen into the exhaust to help burn off any excess fuel. It doesn't affect engine performance either way.
You can replace the cracked tube with vacuum hose from an auto parts store. You can also remove the system, but to do this properly you will need to build block-off plates that bolt to the head in place of the valves, using silicone for a gasket. You may be able to get away with using a rubber vacuum plug over the air inlet of the valve, but a block-off plate is more permanent.
The easiest thing is to use vacuum hose and vacuum hose connectors from an auto parts store to repair the system; plus, it's better for the environment to retain the system.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
