sprockets - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old 12-12-2009, 08:31 PM   #1 (permalink)
Favourite Bike: duh my TT
Other Motorcycle: Sv650
Extra Motorcycle: f4i
sprockets
ok... so when dealing with sprockets how do you know the right setup?
1 this is a dedicated track bike so I am ok with having multiple sprocket setups
I ask this because I was thinking about maybe going up to a 50 tooth in the rear.
I am currently -1/+2 and would like some more acceleration coming out of turns at some of the bigger/faster tracks.
I find that at thunderhill (predominately a big hp track) I am not competitive against newer 600's. I can have a guy completely beaten coming in to the final turn only to have him catch up to me close to the finish line. Now what I am seeing is that they just tend to put more power to the ground then I do. (which is true)... my dyno results had me compared to a built SV
I was talking to a fellow racer and he has a 50 on his r6 and completely tears me apart on the straight. You tend to not see much of 6th gear at THill so I am not too concerned about bouncing it off of the redline on the back straight (6,7,8,9) or the front straight (15,1) if I have too
any thoughts?
I like my setup for Infineon (sear point) and Reno Fernley... It was ok for Streets of Willow and I would need to look at more teeth for ButtonWillow
Matt
AFM #940
2001 Racing Yellow TT600
yakoo11 is offline   Reply With Quote
Old 12-12-2009, 11:23 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
You want to be just about to hit the rev limiter when you brake for the corner after the fastest part of the track, assuming there are no other issues. You may find this gearing screws up another part of the track for you, because you will be out of the powerband in a more critical area, like getting a drive onto the front straight at T-Hill. There's no set answer, and since you are riding a TT600, the chances of finding anybody to compare notes with is very small. It's all going to be trial and error.
Will
SponsorHouse profile
Old 12-13-2009, 06:01 PM   #3 (permalink)
yimmit's Avatar
here is a site that will work out roughly what changes to the gearing will make. although they dont list the tt they do list the speed four and daytona 600
http://www.gearingcommander.com/
yimmit is online now   Reply With Quote
Old 12-13-2009, 09:04 PM   #4 (permalink)
anyone know what sprockets from other bikes fit these bikes? They dont list them in the sizes I want in parts unlimited.
Agkistrodon "aka" billy badass
check out my sponsorhouse profile.
http://www.loopd.com/Members/texaspro/Home.aspx
Agkistrodon is offline   Reply With Quote
Old 12-14-2009, 12:13 AM   #5 (permalink)
Will's Avatar
Front sprocket: '96-'97 ZX6r
Rear sprocket: '01-'03 GSXR
I'm about 99% sure of these. Other years may fit, but I don't know for sure. I used Vortex sprockets on my TT600, if memory serves.
Will
Old 12-14-2009, 12:15 AM   #6 (permalink)
Will's Avatar
Are you planning to run a TT600 in the endurance racing? Vortex makes 675 sprockets, although they don't list them in their sponsored parts list on Sponsorhouse.
Will
Old 12-14-2009, 03:01 AM   #7 (permalink)
Favourite Bike: 2000 TT600
Vortex makes sprockets for the TT600. I bought mine from sumofallparts.net
'00 TT600
'87 GN
GNTurbo6 is offline   Reply With Quote
Old 12-14-2009, 01:06 PM   #8 (permalink)
Favourite Bike: 05 Concours
ncdave's Avatar
Other Motorcycle: 03 Buell XB9R
Extra Motorcycle: 01 Triumph TT600
I've found sprocket choices to be a real art when it comes to what works best at different tracks depending on the tightness of the course.
Attached is a spreadsheet that someone provided to me to have a better view of sprocket changes and power points. it might help you to assess power at different RPMs.
NCDave
05 Kawi Concours, 03 Buell XB9R, 01 Triumph TT600,
99 Honda Superhawk
www.bikepics.com/members/ncdave
ncdave is offline   Reply With Quote
Old 12-14-2009, 09:00 PM   #9 (permalink)
Favourite Bike: Triumph Speed Four
Other Motorcycle: Honda RS 250
any thoughts?
Here's a few thoughts.
The right gearing setup is such that fits the track. In my opinion the less you _have_ to shift the better. You should always be in the rev range on your cornering speeds... so that the bike pulls strong but doesn't run out of revs right when you start opening the throttle. A bit below max torque. And of course tall enough, that you don't run out of revs on the straights.
R6 has a 48 rear sprocket as standard in the 99-05 models, so 50 isn't really that big for it... You can't really compare different bikes and their sprockets. I think the shortest gears I used, when I had an R6 were 14/53. In the Speed Four I have 14/48 if I remember correctly. In my opinion, that's starting to be even a bit on the short side. 2nd is essentially unusable. A gearbox with racing ratios would make it more better again with its taller low gears.
I haven't ever ridden a TT, but I don't think it's that much faster than a Speed Four. Any R6 is a lot faster than a Speed Four. The newer ones are in a completely different league.
Example 1: a few years ago I was riding my Speed Four and '02 R6 on the same day. Both bikes had BT002's. With the R6 I did 1.30 something and with the Speed Four 1.35 something.
Example 2: Last summer I rode my Speed Four (BT002's) and my ex girlfriend's completely standard '06 R6 (Pilot Powers, her suspension settings). Sadly, no AiM in use this time, but the people I was able to hang with but not overtake using the Speed Four were like moving chicanes with the R6.
So, being slower than an R6 is kinda inevitable in my opinion if rider skill is about equal.
FART FYRA
pete2 is offline   Reply With Quote
Old 12-15-2009, 05:52 PM   #10 (permalink)
yes yes and yes the less shifting you have to do the better,
... but I know my goal times are about 3 seconds off of what I want and I know I can make this up in a race but I would rather make it in practice as well. I have duplicate videos here of me on an 05 cbr600 and me on the 01 TT and it's pathetic. I can use the power more efficiently on the cbr and run the cbr 3 seconds faster... My times on the SV are 2 seconds faster. So i know right now that I am not riding the TT properly. Something is wrong somewhere. I got into discussion with EDR (eric dorn) and with TWF (Zoran) about some places where I am having issues on the TT and they seem to agree that it's more power delivery. I am just not putting the right power to the ground at the right time. We are going to work on my exit throttle application and see if we can't figure out how much sooner I could roll on. But my thought becomes is there a sprocket setting that would help put me in a better area of the powerband.
and I have worked out a few turns where I don't down shift prior to entry so I can have more throttle application on the exit.
Matt
AFM #940
sprockets? MidLife C Daytona Deliberations 5 07-18-2009 02:17 PM
Sprockets ?? Shift1 Street Triple Forum 1 07-04-2009 03:07 AM
sprockets customcafe Club Cafe' 4 04-13-2007 01:18 AM
Sprockets ! 14 & 45 or 15 & 45 ? Dingle Triumph SuperSports 5 03-27-2007 02:09 PM
Sprockets.. bgaz Twins Talk 21 07-20-2006 09:47 AM
