Quick action throttle? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Motorcycle.comOntario TourismHonda PowersportsMotorcycle.com Classifieds!
Old 12-01-2009, 10:05 PM   #1 (permalink)
I hate, hate, hate, seriouslly hate how long of a twist it is to WOT on my TT600. If I keep her she will become a track bike, but only if I can shorten the throttle a little. Anyone know where I can find a kit or how I can safely modify the throttle.
Thanks!
Shawn
2008 CBR 1000RR
2001 TT600 Sold, but not forgotten
2004 VW R32 300 NA HP
2005 Silverado DD/toy carrier
beachball6 is offline   Reply With Quote
Old 12-02-2009, 09:35 AM   #2 (permalink)
Favourite Bike: 05 Concours
ncdave's Avatar
Other Motorcycle: 03 Buell XB9R
Extra Motorcycle: 01 Triumph TT600
Seems to me that it's not about the throttle itself, but on the other end going into the throttle body. The question would be how to modify that to open with less pull length. True?
NCDave
05 Kawi Concours, 03 Buell XB9R, 01 Triumph TT600,
99 Honda Superhawk
www.bikepics.com/members/ncdave
ncdave is offline   Reply With Quote
Old 12-02-2009, 10:39 AM   #3 (permalink)
Not really, for instance my CBR can use an R6 throttle it moves the point of inserstion to shorten the turn length to WOT. I mean you could try that but if there is an easier solution that would be best.
2008 CBR 1000RR
Old 12-02-2009, 11:01 AM   #4 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I'm not sure what you mean by the R6 cable moves the point of insertion; insertion into what? The throttle body shaft, or the grip? I believe ncdave is correct here, as the throttle radius depends on the throttle body shaft plate where the cable attaches and the diameter of the hand grip where the cable rides, and not the length of the cable. The length of the cable would change nothing so long as the mounting point onto the clutch cover had the same adjustment. If this point did not have the same adjustment, it would simply move around the adjustment and not the overall throw on the throttle body shaft.
I've never heard any of the track members on here complain about the throttle, but maybe they know how to modify the setup.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 12-02-2009, 02:51 PM   #5 (permalink)
Thats more or less what I meant, maybe just explained better
I find that most of the time WOT takes a full wrist turn + pulling w/ my fingers, which is a little irritating.
2008 CBR 1000RR
Old 12-02-2009, 09:17 PM   #6 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I hated the throttle pull on my TT600 on the track. There is no aftermarket solution I know of, but what you can do is wrap a zip tie around the throttle barrel where the cable winds around it. The larger the diameter, the faster the pull. Or, you could just use a dual cable throttle and ignore the second cable. I didn't try it, so I can't tell you how to do it.
Will
SponsorHouse profile
Old 12-02-2009, 09:32 PM   #7 (permalink)
Favourite Bike: 1995 Speed triple
beachball6, you could try this.
http://g2ergo.com/shop/catalog/Street-4-1.html
If at first you don't succeed, hit it with a bigger hammer
Lushy is offline   Reply With Quote
Old 12-03-2009, 12:14 PM   #8 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
My younger brother put a fat bead of hot glue in the groove that the cable rides in. That basically made the outside circumfrence larger which pulled the throttle quicker. The glue was soft enough to be compressed to make a new groove for a few minutes, then cooled to be hard as a rock. You could try it, you won't lose anyting if you don't like it.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 12-04-2009, 02:24 PM   #9 (permalink)
Favourite Bike: 2000 TT600
A popular upgrade for some old school Honda was to use part of PVC piping to increase the diameter.
'00 TT600
'87 GN
GNTurbo6 is online now   Reply With Quote
Old 12-05-2009, 11:42 AM   #10 (permalink)
Well thank you for all the replys, but I just got a call and the bike is leaving today. Bittersweet it was my first bike, but I could be back on a triumph if I can find a crashed 675 to make into my track bike.
Thanks!
Shawn
2008 CBR 1000RR
Quick Action Throttle Pickle Jim Sprint Forum 8 03-04-2008 04:04 PM
quick action throttle shedman Twins Technical Talk 7 02-06-2008 08:59 PM
Quick Action Throttle? Spendthrift Speed Triple Forum 4 08-13-2007 03:49 AM
Quick Action Thottle Linz Daytona Deliberations 2 05-26-2007 07:12 PM
Quick action throttle sparkyjim Speed Triple Forum 7 01-04-2006 10:35 PM
