Motorcycle.comCommonwealth Motorcycles Soupy's PerformanceSportbikeTrackGearOPP Racing
Old 11-15-2009, 01:38 PM   #1 (permalink)
Favourite Bike: triumph legend 2000
Other Motorcycle: 2003 speed 4
Extra Motorcycle: 79 kawa kz 650
Red face radiator speed4
hi all ,went to check coolant level in the radiator today with bike level i opened the cap and coolant spewed out [engine cold][maybe about a quart'is this something i should be worried about [;is it supposed to be under pressure] i never had this happen before ,also acouple of days ago -battery was compleetly dead,i recharged it and all seems to be wellbut the engine light stayed on for about 20 minutes,iturned the bike off and turned it back on an d light went off ,SPOOKEY ehh thanks mike
irish mike is offline   Reply With Quote
Old 11-15-2009, 08:45 PM   #2 (permalink)
Super Bomboderator
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I don't see how the battery and coolant could have anything to do with each other. Some coolant will flow out when you open the radiator cap, as the overflow tank is located above the radiator and coolant will gravity feed down. However, a quart seems excessive. I suggest making sure the radiator is full and the overflow tank is at the appropriate level when cold; then check the level after you run it hot again and let it cool.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"The philosophers have only interpreted the world, in various ways; the point, however, is to change it."
BombFactory is offline   Reply With Quote
Old 11-15-2009, 11:31 PM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
My guess is you have some air in the system. It expanded and pushed a lot of coolant out. You will have to bleed the air out of the system. My method was to put the bike on a center stand, remove the cap, start the bike, and fill the radiator with the motor running. They squeeze the top radiator hose, refilling as the air burps out. There is a more official way using a bleed valve on the water pump, but I never did it any other way than the low tech burp method.
Will
SponsorHouse profile
Speed4 Used Price... best deal. divino Triumph SuperSports 7 06-05-2009 06:19 PM
alarm for speed4 goldark Triumph SuperSports 2 08-08-2007 11:41 AM
speed4 to tt600 tommer Triumph SuperSports 6 01-16-2007 12:49 PM
06 speed4 v 03speed four AndyS4 Triumph SuperSports 27 07-04-2006 10:04 AM
reliability of speed4 ? scottmc5 Triumph SuperSports 10 03-23-2005 04:34 PM
