Coolant leaks, Water Pump replacement? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-06-2009, 12:40 AM   #1 (permalink)
Favourite Bike: All of them!
Dmitry's Avatar
Other Motorcycle: Vespa
Looking for my O2 sensor I noticed some antifreeze on the floor, looks like it came out of the water pump, I guess time for a new one, so I found similar thread on the tech compendium but it ends with "PM me and I will email you instructions how to replace the pump"
Any tricks to it? looks easy, but I'd rather ask than F something up.
Is it serviceable or replacement only?
Thanks!
Dmitry is offline   Reply With Quote
Old 09-06-2009, 07:16 AM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
As far as I know, you replace the coolant pump.
Will
SponsorHouse profile
Will is online now   Reply With Quote
Old 09-06-2009, 12:43 PM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
Before buying any parts, I would pinpoint where the coolant is coming from. Is it from the crankcase and water pump sealing surface, or is it from the small hole in the water pump housing where the propeller shaft runs? If it is from the sealing surface, you may just need a new o-ring. If it is from the small hole in the housing, it is the shaft seal and you will need another water pump (as Will said, they are not rebuildable).
Talk to a parts department, as you might be able to buy a pump separate from the housing neck, but I'm not sure. The process is pretty straight forward: pull the pump off as one unit (2 bolts), and then separate the pump from the neck housing (2 bolts). Join the neck and a new pump, and reinstall. Depending on what the large neck housing o-ring and smaller water pump o-ring look like, you may want to replace them. Then it's a matter of connecting all the hoses back up and thoroughly bleeding the system of air.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 09-06-2009, 06:39 PM   #4 (permalink)
Dmitry's Avatar
Cool, Thanks!
Will call a dealer first thing Tuesday.
Did 150 miles today, no leak. Will check again when it cool down.
Coolant Pump Replacement revolve99 Speed Triple Forum 0 06-02-2009 01:33 PM
Water Pump petej64 T3 Sport / Touring Forum 3 02-03-2009 12:07 PM
The new BMW WATER PUMP!? ohiorider Twins Technical Talk 10 08-31-2007 01:50 AM
water pump accpilot Speed Triple Forum 3 05-14-2006 01:03 PM
Water Pump TexasRocket The Rocket Science Forum 1 09-13-2005 08:41 PM
