Wont start but Bickfires - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew Bonneville
Old 09-02-2009, 02:09 PM   #1 (permalink)
Newbie
Favourite Bike: 01 tt600
I have an 01 Triumph TT600 (40k mi) and took it apart to fix an oil leak from the “top gasket”. After putting it back together I shot some injector cleaner in on the valves ( I am betting my problem) because the valves were gunky. It started up (check engine light came on) with a lot of white smoke but I took it around the block.
Then next day it does not turn over but has a loud backfire, it will act like it wants to start but then backfires.
Took it apart checked the plugs (autolite's) gap is .03in two were a little wet so I dried them and put back in. still no start just backfire. Took plugs out again and they are dry.
I have let it set for 3 day but still no luck. Dealer can get me in, in about 2 weeks but I want to ride if I can fix it.
Please help. Thank you
gkdowning is offline   Reply With Quote
Old 09-05-2009, 12:11 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I guess none of us knows. Keep us posted on what you find out.
Will
SponsorHouse profile
Old 09-05-2009, 01:26 PM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
Depending on how much injector cleaner you poured into the throttle bodies, some could have found its way into the IACV (the quadropus looking thing with the large hose attaching to the airbox). If there is a malfunction in the IACV (i.e. fluid or other debris in it), it can cause hard starts and backfiring. The injector cleaner being in the combustion chambers and intake runners is not going to cause the issue you describe.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Wont Start jbmrrs Sprint Forum 22 06-17-2009 01:48 AM
05 triple wont start *** tracktriple05 Speed Triple Forum 4 06-16-2009 10:30 PM
New S3 owner! To bad it wont start.......... dave-o Speed Triple Forum 13 04-01-2008 02:13 PM
HELP Please - Tiger wont start PeteH Maintenance & Workshop Talk 6 02-26-2008 08:54 PM
Wont Start!! Classic, Vintage & Veteran 32 05-08-2005 12:18 PM
